October 10, 2022 at 11:36 am
mg7234
SubscriberDoes anyone know if/how you can save a material that you have created yourself with the Material Designer and then export it as a material for further calculation in FEMFAT? The material is a short fiber reinforced plastic.
Thank you!
October 12, 2022 at 4:27 pm
David Mercier
Ansys EmployeeHi, sorry MaterialDesigner does not support the export to FemFat.
December 4, 2022 at 5:25 am
bhagwantP
Ansys EmployeeHello mg7234,
Is that you are confined to user only material designer? What if you try other modules like ACP (Ansys Composite PrepPost)/ Engineering Data tab into Ansys mechanical and use them to export to utilse materials into FEMFAT?
Thanks
- The topic ‘Export Material Data’ is closed to new replies.
1487
1318
1158
