February 11, 2021 at 6:01 pm
Acosta
SubscriberI have recently drawn a part on spaceclaim using the 2021 R1 version and want to save it as a stl., however it's only possible to save it as scdoc, was this supposed to happen ? nI have already tried save as and export.nn -
February 12, 2021 at 4:27 am
1shan
Ansys EmployeeHelloArray,I understand you already tried it but could you try the save as option once again and be sure. I use the same version and can find .stl after clicking the pull down bar.nRegards,Ishann -
February 12, 2021 at 4:38 am
Keyur Kanade
Ansys EmployeeFor student version step, iges are included only for import and not for export. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
Keyur Kanade
Ansys EmployeeCheck this nn -
February 12, 2021 at 1:12 pm
Acosta
SubscriberThanks nDo you have any solution for this, other than buying ansys license? n -
February 12, 2021 at 2:07 pm
Keyur Kanade
Ansys Employeewhy do you want stl? n-
June 12, 2023 at 9:38 pm
Guardian Arias
Subscriber3D Printing slicers need STL, OBJ, or AMF files to be able to prep a modle for printing. Im currently stuck on the same issue when using Ansy Student SpaceClaim. I actully love this modeler and I have gone from not knowing how to make a cube to tinkering with alternative ways of making gears that are more compatible with 3D printing methods since involute gears are not all that great when printed. But unfortunately since RS Design Spark chose to lock out STLs I'm looking for alternatives. As some might know most worthwile companies are willing to buy an employee whatever softwere they want so long as its justified and especially if the employee already knows how to use it but whatever I guess.
- The topic ‘Export formats from spaceclaim’ is closed to new replies.
6430
