March 31, 2023 at 7:54 am
l.geronzi
SubscriberHi,
I am executing some simulations with a parametric mesh in Fluent (running in parallel).
For every mesh, I would like to export the pressure at the wall or the wall shear stress for example.
In the journal, I'm using /file/export ascii wss (2 3 4 5 6 7 8 9 10) yes wall-shear () no
where from (2.... to 10) are the surfaces of the mesh. It works but nodes are always numbered from 1 to n and there is no nodal correspondence (probably due to the parallel partition?). It means that in row 1 sometimes I have node 2034, sometimes node 6885, sometimes node 99999 ecc.
I need to create a list where on row x there are always results associated with the same node id even if its position has changed in space due to the modified parametric mesh.
How can I do? Is it possible to export Node Id in Fluent?P.S. I know that CFD post is a solution but I need to do it directly in Fluent.
Thank you.
March 31, 2023 at 10:25 am
Forum ModeratorFluent is an unstructured solver, and the node IDs aren't necessarily static definitions: it's why it's always a good idea to write case and data on finishing a run.
What exactly are you trying to figure out?
March 31, 2023 at 2:08 pm
l.geronzi
SubscriberOk, it’s a pity. I need to create a ROM (without using the RBP extension).
At this point, CFD post is the only possibility. I put here the solution I will use in CFD-Post if any user will be interested in future. I stored the solution for every parametric mesh in a new cas and dat file.
I used a loop in CFD-Post where n is the number of simulations.COMMAND FILE:
CFX Post Version = 23.1
END
DATA READER:
Clear All Objects = false
Append Results = true
Edit Case Names = false
Multi Configuration File Load Option = Last Case
Open in New View = true
Keep Camera Position = true
Load Particle Tracks = true
Construct Variables From Fourier Coefficients = true
Open to Compare = false
Files to Compare =
END
!$i = 1;
!while ($i < n){
!if($i<2){
DATA READER:
Run Selection = “Simulation/Run/cff-restart-dat”
END
>load filename=D:/Leonardo/ROM_DT/ROM_SSM_files/dp0/FLU-1/Fluent/SSM-$i.cas.h5, force_reload=true
!else {
DATA READER:
Domains to Load=
END
> load filename=D:/Leonardo/ROM_DT/ROM_SSM_files/dp0/FLU-1/Fluent/SSM-$i.cas.h5, \
case=Case SSM 1.cas, force_reload=true
EXPORT:
ANSYS Export Data = Element Heat Flux
ANSYS File Format = ANSYS
ANSYS Reference Temperature = 0.0 [K]
ANSYS Specify Reference Temperature = Off
ANSYS Supplemental HTC = 0.0 [W m^-2 K^-1]
Additional Variable List =
BC Profile Type = Inlet Velocity
CSV Type = CSV
Case Name = Case SSM 1.cas
Export Connectivity = Off
Export Coord Frame = Global
Export File = D:/Leonardo/ROM_DT/ROM_SSM_files/user_files/wss-$i.csv
Export Geometry = On
Export Location Aliases =
Export Node Numbers = On
Export Null Data = On
Export Type = Generic
Export Units System = Current
Export Variable Type = Current
External Export Data = None
Include File Information = Off
Include Header = On
Location = arch
Location List = arch,ascending_aorta,bc,descending_aorta,end_ascending_aorta,\
high_valsalva_sinuses,lcc,low_valsalva_sinuses,ls
Null Token = null
Overwrite = On
Precision = 8
Separator = “, “
Spatial Variables = X,Y,Z
Variable List = Wall Shear
Vector Brackets = ()
Vector Display = Scalar
END
>export
!$i ++;
- The topic ‘Export Fluent Results with node ID’ is closed to new replies.
5874
1306
