March 10, 2024 at 10:10 pm
Krisztián Szabó
SubscriberHello, what is the easiest way to export material from Maxwell 3-D to Fluent?
I am working on the heating of a transformer, I want to simulate the flow and I want the materials to be the same.
Thank you very much! -
March 12, 2024 at 3:54 pm
Ivonne Marti
Ansys EmployeeHello Krisztián,
Maxwell materials look at the electromagnetic characteristics and the materials in Fluent to the fluid-dynamic ones. This is the reason why the materials are not shared between both tools and why the input characteristics are different.
Since each tool has his own material library, you can try to choose same materials and re-write the common characteristics to be the same.
I hope this helps. Ivonne
- The topic ‘Export a material from Maxwell to Fluent’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1318
1156
