LS Dyna
LS Dyna
Explicit analysis in ansys ls dyna
    • Skabhishek
      I want to model a 5 layered composite and perform an impact analysis in ansys ls dyna, the element i want to use is shell 163. But I can't find any option to give layered properties. How will I give the layers for that? Also if I'm using solid 164 ,how will I give the ply angle?
    • Sandeep Medikonda
      This element type is obsolete. Use ACP Pre-processing to define your shell layers and link it to mechanical.
  • The topic ‘Explicit analysis in ansys ls dyna’ is closed to new replies.
