December 28, 2021 at 11:31 am
Alex
Hi Support Team
After trying out the trial version of SpaceClaim I purchased the software a few days ago. I uninstalled the trial version and installed the version provided from this web page.
Now I have an issue with the excel add-in. As you can see at the screenshots attached the excel-add-in is shown as inactive. In the ribbon tab menue there is no excel mark to check.Â
This is strange, because with the trial version this function was available.
Yesterday I uninstalled SpaceClaim and reinstalled it, but there is no difference.
The same thing appears on my second PC. I downloaded the latest version from this Ansys site (Discovery Downloads - Knowledge Base - Ansys Discovery Forum), but the Excel-add-in is marked as inactive also.
The installed version on both mashines is: (2021.2.0.06011) (Lizenz-ID: ANSYS-Subscription).
OS is Windows 10 pro and for the second PC Windows 11 pro.
At the moment I do not have any idea what’s going wrong – do you have any idea how to fix this issue?
Best regards
Alex
December 28, 2021 at 12:00 pm
Devendra Badgujar
Forum ModeratorHello Alexander Faller
Let me check and get back to you on this.
December 28, 2021 at 12:36 pm
Devendra Badgujar
SpaceClaim must be restarted before the updated settings will be applied. Please try restarting SpaceClaim after you update the excel add-in and you should be able to see the excel in the ribbons tab.
Let me know if the issue still persists after doing this.
December 28, 2021 at 1:07 pm
Alex
SubscriberHello Devendra BadgujarÂ
unfortunately this makes no change. I also tried out to reset all user settings and also to change from German language version to english - so the issue still persists.
December 28, 2021 at 1:46 pm
Devendra Badgujar
Can you please specify which version of Excel you are using?
Can you please try using the newer versions of Excel ?
Also, make sure antivirus has been turned off.
December 28, 2021 at 4:14 pm
Alex
thank you very much for your kind support - I just updated to the latest version of MS office - now all works fine :-)!
I will mark the request as answered.
Best regards
Alex
- The topic ‘Exel Add-in inactive’ is closed to new replies.
