July 2, 2023 at 4:31 pm
Sampath kumar A V N
SubscriberMostly i have seen the simultion of synchronous reluctance motor is carried out with current excitation.Why can't we simulate with voltage excitation?
July 3, 2023 at 8:10 am
Bo Ren
Ansys EmployeeHello Sampathkumar,Â
Thanks for your question.Â
For the synchronous reluctance machine, the voltage excitation is available and you could set this by employing the external circuit or set in the 'Excitation'.Â
Thanks
Best regards
Bo REN
July 3, 2023 at 9:05 am
Sampath kumar A V N
SubscriberI am very much thankful for the reply sir...If we go for voltage excitation, we can't have a control over phase advance angle.Is it so? May i know the circuit how to build for voltage excitation?
July 3, 2023 at 9:13 am
Bo Ren
Ansys EmployeeHello,Â
Thanks for the reply.Â
The phase advance angle could be controlled by including this into the voltage expression when you set the excitation. For example:
Um*sqrt(2) * sin(2*pi*Freq1*time+PhaseAdvance)
ThanksÂ
Best regards
Bo REN
- The topic ‘Excitation to synchronous reluctance motor’ is closed to new replies.
