March 3, 2024 at 11:24 pm
jsan
SubscriberI heard that there is a case of interpreting Mach number more than 10 in Fluent Pressure based poured solver, can you tell me where the data is?
Is it possible to solve a case with a Mach number of 10 or more on the Fluent Pressure based coupled solver? -
March 4, 2024 at 7:01 am
SRP
Ansys EmployeeHi,
I suggest you to check tutorial on high mach number: Chapter 26: Modeling Ablation (ansys.com)
Hope this helps you
March 4, 2024 at 7:03 am
Essence
Ansys EmployeeHello,
I believe Mach number greater than 5 calls for a hypersonic flow, as air molecules will start to dissociate at such high speeds. You might want to use density-based solver instead of pressure-based. I would also recommend you to use two-temperature model with cfd_hsf license installed on your system.
- The topic ‘Example of flow analysis with a Mach number of 10 or more on a Fluent Pressure b’ is closed to new replies.
- affinity not set
4317
1494
1375
1197
