Ansys Free Student Software
everytime i open ansys i get : could not connect to lisense server : 55654@127.0.0.1. System error0″
    • shreepatil14
    • George Karnos
      This may be firewall related.
      Make sure exceptions are added for:
      C:\Program Files\ANSYS Inc\ANSYS Student\v212\licensingclient\winx64\ansyscl.exe
      C:\Program Files\ANSYS Inc\ANSYS Student\v212\Framework\bin\Win64\AnsysFWW.exe
      C:\Program Files\ANSYS Inc\ANSYS Student\v212\aisol\bin\winx64\AnsysWBU.exe
    • shreepatil14
      How to do it and where from do it can u please answer
    • George Karnos
      Open Windows Firewall
    • shreepatil14
      Thank you ­ƒî© I will try it right away
    • shreepatil14
      When I open ansys this pop-ups---. Could not connect to license server: 65015@localhost. System error: 0""
    • George Karnos
      It still seems like something is blocking communication If you open a Dos command prompt and type in the following, what is returned?
      ping localhost
    • shreepatil14
      Where can I find it and how do I do it can you please tell me
    • George Karnos
      Open a command prompt by typing in cmd in the serach field
      Then when it opens, type in: ping localhost
      C:\TEMP>ping localhost
      It should return something similar to:
      Pinging Server [127.0.0.1] with 32 bytes of data:
      Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
      Ping statistics for 127.0.0.1:
      Packets: Sent = 4, Received = 4, Lost = 0 (0% loss) Approximate round trip times in milli-seconds:
      Minimum = 0ms, Maximum = 0ms, Average = 0ms
    • shreepatil14
      I got this after typing in command prompt
      What shall I do next
    • George Karnos
      What do you get when you type in:
      ping -4 localhost
    • shreepatil14
      This is what I got
    • George Karnos
      I apologize, remove the space between the - and the 4
    • shreepatil14
      Sorry
    • George Karnos
      ping -4 localhost
    • shreepatil14
      Is this correct
    • George Karnos
      No.
      ping -4 localhost
    • shreepatil14
      If i still made a mistake in typing please give me reference text where "blank space is denoted by underscore" and I will do it
      Again sorry for the inconvenience
    • shreepatil14
      Can you please give me answer
    • shreepatil14
      Hello please clarify my doubt
    • George Karnos
      ping look good.
      There has to be something blocking communication on your system.
      Do you have any other firewall/virus scanning software installed?
      MacAfee, Norton, Kaspersky...etc?
      If you do, add the same exceptions as above.
    • shreepatil14
      A new error occurred whin I opened the software saying :Could not connect to license server: 54832@127.0.0.1. System error: 0""
      What should I do
    • George Karnos
    • George Karnos
      @shreepatil14
      Just performing a follow up
      What all firewall/security softwares do you have installed?
    • Kai Luo
      Hello sir, is your problem solved? I'm in the same situation now and I can't find any solution on the Internet.?
Viewing 24 reply threads
  • The topic ‘everytime i open ansys i get : could not connect to lisense server : 55654@127.0.0.1. System error0″’ is closed to new replies.
