November 16, 2018 at 8:44 pm
xiaojiangyou
SubscriberIs it possible to initiate evaporation under boiling point in Ansys Fluent?
November 18, 2018 at 3:00 pm
Karthik Remella
AdministratorHello,
You will need to elaborate a little more on this question. Are you attempting to generate a mechanistic model for boiling through thin-film evaporation? Are you attempting to model the interface? Are the two liquids immiscible? If these are your question, then the answer is 'YES'.
Please elaborate your question so we understand this better.
Also, I'm moving this question to the 'Fluid Dynamics' thread so it gets better visibility.
Thank you.
Best,
Karthik
November 19, 2018 at 2:27 pm
xiaojiangyou
SubscriberHi Karthik,
Thanks so much for your reply. I want to generate a mechanistic model for evaporation through thin-film evaporation (without boiling happening). Is this possible in FLUENT?
Best
xiaojiangyou
November 19, 2018 at 3:19 pm
DrAmine
Ansys EmployeeEvaporation under boiling limit will only work if you have two phases where one of them is a mixture containing the component in different material state like: water-film and wet-air.
Do you need to resolve the film? If not you can rely on the Eulerian Wall Film to do that.
November 19, 2018 at 5:47 pm
xiaojiangyou
SubscriberHi Amine,
Thanks so much for your suggestion! I'll try with water-film and wet-air and see if I can see evaporation happening!!!
Thanks again!!!!!!!!!!
Best
xiaojiangyou
November 19, 2018 at 10:30 pm
Karthik Remella
AdministratorHello,
Just to add to Amine's comments, if you would like to resolve the thin film, you should be able to do this through a VOF model. However, this is going to be computationally expensive. Not to mention that you might have to deal with spurious currents and other numerical instabilities.Â
I hope this gives paints a complete picture.
Thanks.
Best,
Karthik
November 20, 2018 at 2:41 am
xiaojiangyou
SubscriberThanks for your adding Kremella!
- The topic ‘evaporation under boiling point’ is closed to new replies.
6254
