3D Design
3D Design
Errors after deleting some features
    • matahari
      Hello everyone,
      I'm trying to slice up a body in order to refine the mesh where I need it. First I simplified the model in SpaceClaim by removing some features using Fill tool. Then I come across following errors in Mechanical when I try to mesh or solve.
      One or more surfaces or surface boundaries might not be oriented correctly.
      A body was processed that had faces with no facets. Mesh generation and mass property calculations may be impacted.
      I don't have this problem when doing the same with non-simplified model. I tried repairing both in SpaceClaim and DesignModeller and it didn't help. The model is, by the way, imported, I didn't make it myself. Also, there are places where I can't even slice, for example, left of the vertical line here, where the curvature starts. I get following error. (I will put those in the comments, I can't seem to be able to do it here.
    • matahari
      " alt="" width="308" height="174">
    • matahari
    • Keyur Kanade
      in spaceclaim right click on the model in structure tree and select check geometry.
      if geometry has any faults, please repair it.
      please create a plane where you want to slice the geometry. then slice the geometry with the plane in spacececlaim.
      https://www.youtube.com/watch?v=EJ7DvfzDYwQ
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘Errors after deleting some features’ is closed to new replies.
