October 29, 2021 at 8:35 pm
laraaraujo
Subscriber>>>--------------------------------------->
Start Installation: **** out 29 17:17:52 2021
Revision: 2021 R2
Platform specifics:
Windows
Username of Installer: DELL-LARALARA
User Has Administrator Privileges
C:UsersLARAAppDataLocalTempans_install_tmp17252instcore.exe -usetempdir C:UsersLARAAppDataLocalTempans_install_tmp17252 -launchdir C:UsersLARADesktopAplicativosANSYSACADEMICSTUDENT_2021R2_WINX64 -admin
Initial mount directory:
Installation Directory:
C:Program FilesANSYS IncANSYS Student
Windows x64
EnSight
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
Extraction: C:UsersLARADesktopAplicativosANSYSACADEMICSTUDENT_2021R2_WINX64instcore clCOMMON.TGZ ...
Extraction: C:UsersLARADesktopAplicativosANSYSACADEMICSTUDENT_2021R2_WINX64instcore clWINX64.TGZ ...
Extraction: C:UsersLARADesktopAplicativosANSYSACADEMICSTUDENT_2021R2_WINX64studentWINX64.7z ...
Extraction: C:UsersLARADesktopAplicativosANSYSACADEMICSTUDENT_2021R2_WINX64licenseWINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
"C:Program FilesANSYS IncANSYS StudentShared Filesinwinx64 clsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl" -silentinstallclient -release "2021 R2" -lang en-us
Licensing configuration has completed.
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCommon.exe
Configuring ANSYS TurboGrid ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigTG.exe
Creating Start Menu items for Ansys client licensing ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigWB.exe
Running C:Program FilesANSYS IncANSYS Studentv212FrameworkinWin64Ans.DriverSetup.exe
Running "C:Program FilesANSYS IncANSYS Studentv212RSMinAnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2021 R2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2021 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Configuration 2021 R2.lnk
Creating Start Menu Shortcut for RSM 2021 R2 Job Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Job Monitoring 2021 R2.lnk
Creating Start Menu Shortcut for RSM 2021 R2 Cluster Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerRSM Cluster Monitoring 2021 R2.lnk
Creating Start Menu Shortcut for ARC 2021 R2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsAnsys 2021 R2Remote Solve ManagerARC Configuration 2021 R2.lnk
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigAQWA.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCFX.exe
Configuring ANSYS Viewer ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
Configuring ACP ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigACP.exe
Configuring Help ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigFORTE.exe
Configuring EnSight ...
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigEnsight.exe
Running C:Program FilesANSYS IncANSYS Studentv212commonfilesconfigswinx64configAnsConfigFENSAP.exe
Running "C:Program FilesANSYS IncANSYS Studentv212aisol..commonfilesCADinwinx64Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsLatestCADConfigurationMgr.log
MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsLatestCADConfigurationMgr.log
ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv212CADConfigLogsCADConfigurationMgr.err
Prerequisites ..... Configure Success
SC Workbench PlugIn ..... Configure Success
Discovery Workbench Plugin ..... Not Configured
Successfully created file associations.
Installation Complete: **** out 29 17:21:41 2021
November 1, 2021 at 11:40 amANSYS_MMadore
Forum ModeratorDo you encounter problems trying to run Ansys Student? The message regarding CADConfigurationMgr.log shouldn't be a problem.
November 2, 2022 at 3:06 pm
Andrii Bulan
Start Installation: Ср Лис 2 17:02:35 2022
Revision: 2022 R2
Platform specifics:
Windows
Username of Installer: DESKTOP-E618NB8\³������
C:\Users\C099~1\AppData\Local\Temp\ans_install_tmp10844\instcore.exe -usetempdir C:\Users\C099~1\AppData\Local\Temp\ans_install_tmp10844 -launchdir D: -admin
D:
C:\Program Files\ANSYS Inc\ANSYS Student
Windows x64
Ansys, Inc. Products
Explicit Dynamics
Autodyn
Fluid Dynamics
CFX (includes CFD-Post)
Chemkin
Energico
Model Fuel Library (Encrypted)
Reaction Workbench
EnSight
FENSAP-ICE
Fluent (includes CFD-Post)
Forte (includes EnSight)
Polyflow (includes CFD-Post)
TurboGrid
Offshore
Aqwa
Structural Mechanics
Mechanical Products
Ansys Geometry Interfaces
Discovery Geometry Interface
SpaceClaim Geometry Interface
Extraction: D:\instcore\tcl\COMMON.TGZ ...
Extraction: D:\instcore\tcl\WINX64.TGZ ...
RSS is disabled
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCommon.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigHelp.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigWB.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\Framework\bin\Win64\Ans.DriverSetup.exe
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\AnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2022 R2 ...
Done!
Creating Start Menu Shortcut for RSM 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Configuration 2022 R2.lnk
Creating Start Menu Shortcut for RSM 2022 R2 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Job Monitoring 2022 R2.lnk
Creating Start Menu Shortcut for RSM 2022 R2 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\RSM Cluster Monitoring 2022 R2.lnk
Creating Start Menu Shortcut for ARC 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\ARC Configuration 2022 R2.lnk
Creating Start Menu Shortcut for DCG 2022 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2022 R2\Remote Solve Manager\DCG Configuration 2022 R2.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v222\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCFX.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCHEMKIN.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigEnergico.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigRDWorkbench.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigEnsight.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFENSAP.exe
Configuring ANSYS CFD Post ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigCFDPost.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFLUENT.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigPolyflow.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigFORTE.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigTG.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigAQWA.exe
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigANSYS.exe
Configuring ACP ...
Running C:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles\configs\winx64\config\AnsConfigACP.exe
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v222\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\Latest\CADConfigurationMgr.log
ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v222\CADConfigLogs\CADConfigurationMgr.err
Installation Complete: Ср Лис 2 17:04:06 2022
November 1, 2021 at 7:29 pmlaraaraujo
SubscriberI wasn't able to go to the last page on the installer 'cause the button "next" was disabled... so I thought the installation hasn't finished. But I've just ran Ansys student... i think everything it's ok. Thanks!
November 2, 2022 at 3:07 pmAndrii Bulan
SubscriberHelp me
Viewing 3 reply threads- The topic ‘“ErrorLogger.errorFilePath” I can’t finish my installation… May i have any help??’ is closed to new replies.
5819
