September 26, 2023 at 2:22 pmPablo MartÃnez ReviriegoSubscriber
I am trying to use PML wizard set up for a boundary condition in a circular waveguide in an eigenmode problem in HFSS. However, every time I finish the wizard, HFSS collapses and stops working. I think this could be some type of bug since when I do the same for a rectangular surface, the software works fine. Do I need to do any previous step for a circular surface?Â
In addition, this problem does not happen in previous version (2020R2). I am working on 2023R1.
Thank you very much in advance,
Kind regards,
Pablo
September 28, 2023 at 12:32 pmPraneethForum Moderator
Hi Pablo,
Thank you for reaching out to the Ansys learning forum.
It looks like you have posted the same question in another thread with link - Problem with PML in circular surface in eigenmode HFSS. Please note that your question is addressed there.Â
As per forum rules, I am closing this thread for further replies as this is a duplicate post. Use the mentioned thread if you have any follow-up queries.Â
Best regards,
Praneeth.
- The topic ‘Error with PML in circular surface for eigenmode HFSS’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
1406
599
591
550
366
