January 24, 2022 at 6:24 am
danielbar
Subscriberrecently I couldn't create wave/pressure contours or generate plots via the Aqwa GS due to the fact that .PAG files are not created. I checked it also on files that it used to work for in the past. Does anyone know what the problem could be?
Thanks.
January 24, 2022 at 5:49 pmYu Bi
Ansys EmployeeHi, this problem is due to a 'Y2K' bug in Aqwa which affects all released Aqwa versions since 1stJanuary 2022.This bug will be fixed in the 2022R1 service pack in mid-February. The workaround to generate *.PAG file is to manually add SEAG data record (Aqwa Reference Manual Section 6.13) in the *.DAT file before running Aqwa. However, for the pressure contour, it can only be plotted in the Aqwa Workbench editor, i.e. AqwaGS cannot plot the pressure contours currently.
January 25, 2022 at 6:33 amdanielbar
SubscriberThank you for your detailed answer! I appreciate it!
Viewing 2 reply threads- The topic ‘Error with Aqwa GS- PAG: files are not created’ is closed to new replies.
4607
1510
1386
1209
