January 9, 2019 at 1:01 pm
January 9, 2019 at 1:39 pm
Sandeep Medikonda
Ansys EmployeeNavven,
Where are you running this? On your local machine or on a cluster?
If it is run locally? Kill all processes, better if you can restart your machine.
Turn off Distributed solve and see if it runs?
This can be done using Tools>Solve process Settings>Advanced and turn off Distribute Solution.
Sandeep
Guidelines on the Student Community -
January 9, 2019 at 1:54 pm
naveen28
SubscriberSandeep,
Thanks for your response. After turning off distributed solve, I am able to solve it.
Even though I am runing it in local machine, why am I getting this error.
Thanks,
Naveen
January 9, 2019 at 3:30 pm
Sandeep Medikonda
Ansys EmployeeBecause by default distributed solve is turned on and if the host machine has limited memory or limited disk space or some other systems issue...it might run into problems like in your case. Since you are running on a local machine you are not loosing out much on the speed by turning off distributed solve.
January 10, 2019 at 6:05 am
naveen28
SubscriberGot it. Thank you Sandeep!
- The topic ‘Error while solving static structural problem’ is closed to new replies.
6450
