May 12, 2018 at 3:10 pm
May 12, 2018 at 3:29 pm
raul.raghav
SubscriberCould you share the workbench archive file here so we could take a quick look?
May 13, 2018 at 2:37 pm
Raunak15
SubscriberI have attached the workbench archive file.
Thank You 1
May 13, 2018 at 5:17 pm
peteroznewman
SubscriberI recognized the file name and used ANSYS 18.2 to open that archive, which is from the CornellX course on edX.org. They recommend you install ANSYS Student 18.2 for that course.
I suggest you uninstall ANSYS AIM 19.0 and then install ANSYS Student 18.2, which can be found under Prior Release link.
If installing AIM 19.0 was intentional and not a mistake, then reply to confirm that and we can talk about how to build that model in AIM.
May 16, 2018 at 12:56 pm
Raunak15
SubscriberIt works fine on 18.2 but I was wondering if there is a workaround other than building the model from scratch.
May 16, 2018 at 2:21 pm
peteroznewman
SubscriberI don't know about moving from Workbench to AIM, but you can export the geometry out of the Geometry editor and save that to a file, then in AIM, you can import that geometry from that file.
May 19, 2018 at 6:48 pm
Raunak15
SubscriberYes that works!
Thanks for the tip.
- The topic ‘Error while opening wbpz file’ is closed to new replies.
6600
1311
