Preprocessing
Preprocessing
Error while importing Geometry file from SpaceClaim into Fluent with meshing
    • mjmohd
      Greetings,
      I'm getting this error when I import the Geometry from Spaceclaim into Fluent. I managed before to import the same Geometry and do the Simulation but it is not working anymore!
      the error I'm getting in Fluent:
      C:Usersmajd_DesktopBAAnsysAnsys 8BA_filesdp0FLTGFluent>"C:Program FilesANSYS IncANSYS Studentv212/scdm/SpaceClaim.exe" /headless=true /Splash=False /WELCOME=false /CommandLineAddInsOnly=true /ADDINMANIFESTFILE="C:Program FilesANSYS IncANSYS Studentv212/scdm/ConversionAddInXml.txt" /EXECUTECOMMAND=ConversionAddIn.Convert No mathcing resource could be found for length with Id:
      Status1:ConverterInput16379354613496:C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc
      11/26/2021 3:01:40 PMError2:ConverterInput16379354613496:C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc
      Error: FMD conversion of "C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc" has failed!
      Error Object: #f
    • Vigneswaran Sridharan
      Hi Please check if It works with the conversion .scdoc -> .fmd in SpaceClaim and then import the fmd file in Fluent.
      If it works, I suspect the anti-virus blocking some functionality inside Fluent for the conversion.
      Vigneswaran
    • mjmohd
      Hi, thank you a lot for your response.
      so I'm trying to export .scdoc as .fmd in SpaceClaim but I can't find other types than .scdoc!
      I'm really new to Ansys World and if you can walk me through this problem I will appreciate it a lot.
    • mjmohd
      so I think it is a problem with the versions Ansys 2020 vs.2021!
      I tried to do my simulation using Workbench 2020 and it worked.
      I had even different supported types in SpaceClaim 2020 in comparison to the newer version 2021!
      do you know why this is happening?
      I tried to reinstall the latest version of Ansys again but the problems are still there!
  • The topic ‘Error while importing Geometry file from SpaceClaim into Fluent with meshing’ is closed to new replies.
