September 30, 2020 at 7:20 pm
joshua.clinger.ctr
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHi, I tried installing the License Manager on my License server and these are the errors and messages that I received when attempting to do. The are in the attachments. Any help would be great! Thank you -
September 30, 2020 at 8:06 pm
joshua.clinger.ctr
SubscriberAlso received this message. Error: The following required file does not exist:
C:Program FilesAnsys IncShared FilesLicensingwinx64ansysli_server.exe
October 1, 2020 at 7:30 am
Naresh Patre
Ansys EmployeeHello Matt Madore
Can you please assist with this installation issue?
October 1, 2020 at 11:50 am
ANSYS_MMadore
Forum ModeratorJoshua can you try to manually stop and remove "FlexLM for Ansoft". You can attempt this from the Windows Control Panel Add/Remove Programs. Having this installed will prevent the ANSYS License Manager installation.
You can also try running these commands from an Administrator command prompt.
sc stop "FLEXlm for Ansoft"
sc delete "FLEXlm for Ansoft"
Once done, please try reinstalling the ANSYS License Manager.
October 1, 2020 at 1:02 pm
joshua.clinger.ctr
SubscriberThat makes sense. But I do have licenses running through FLEXlm for Ansoft. If I do remove that program, is there a way that I can get that back without losing my licenses?
Thank you
October 1, 2020 at 4:33 pm
joshua.clinger.ctr
SubscriberMatt Madore That makes sense. But I do have licenses running through FLEXlm for Ansoft. If I do remove that program, is there a way that I can get that back without losing my licenses?
Thank you
October 1, 2020 at 4:36 pm
ANSYS_MMadore
Forum ModeratorJoshua Any license you may have under FLEXlm for Ansoft should run under the ANSYS License Manager using the common vendor daemon. You can install them under the ANSYS License Management Center.
October 2, 2020 at 3:10 pm
joshua.clinger.ctr
SubscriberGood Day, Matt Madore I did remove all tracing of "FLEXlm for Ansoft," and now I am receiving this error. I feel like I am get closer than I was before but I wanted to reach out to the expert about doing this correctly because I want to get it right without myself making a mistake. Thank you🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 3:17 pm
ANSYS_MMadore
Forum ModeratorDid you go to the ANSYS License Management Center to install the license file?
October 2, 2020 at 3:19 pm
joshua.clinger.ctr
SubscriberMatt Madore you can do that before actually completing the install of the ANSYS License Manager?
October 2, 2020 at 3:29 pm
ANSYS_MMadore
Forum ModeratorNo, but because you had a previous failed install it sees the new install as an "update" so looks for an existing license by default. Typically you would not see this message for a first time installation.
October 2, 2020 at 4:31 pm
joshua.clinger.ctr
SubscriberMatt Madore now I am running into an issue where the "FLEXnet Licensing" is not running. It looks like it has something to with the TCP 1055 port but after looking over a few things, I did not notice any issue. Maybe you can catch them. By the way the name of the PC I doing this on is FLEX-PC. Thank you🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 4:37 pm
ANSYS_MMadore
Forum ModeratorPlease try rebooting the machine.
October 2, 2020 at 5:55 pm
joshua.clinger.ctr
SubscriberI did reboot the entire machine and now I am getting different error message with "Licensing Interconnect and not running." When it says kill them, it doesn't mean delete them does it?🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys">https://www.ansys.com/legal/terms-and-conditions">Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 5:57 pm
joshua.clinger.ctr
SubscriberMatt Madore It can't mean within the Task Manager, because they are not running as processes.
October 2, 2020 at 6:01 pm
ANSYS_MMadore
Forum ModeratorPlease provide the contents of the ansysli_server.log and license.log files from C:Program FilesAnsys IncShared FilesLicensing.
October 2, 2020 at 6:13 pm
joshua.clinger.ctr
SubscriberMatt Madore here it is.🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 6:17 pm
ANSYS_MMadore
Forum ModeratorPlease check the FLEXlm log file C:Program FilesANSYS IncShared FilesLicensinglicense.log
October 2, 2020 at 6:25 pm
joshua.clinger.ctr
SubscriberMatt Madore here is that log.🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 6:39 pm
ANSYS_MMadore
Forum ModeratorThere appears to be an issue with the license file. The message would indicate the hostid of the file may have been changed. That results in: Invalid license key (inconsistent authentication code). I'm going to reach out using our alternative discovery support for further information.
October 2, 2020 at 6:53 pm
joshua.clinger.ctr
SubscriberMatt Madore here are some screens of some things involving what the hostid of the machine is, and the actual license file with the hostid in it.🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 2, 2020 at 7:14 pm
ANSYS_MMadore
Forum ModeratorPlease follow these steps for gathering the server side diagnostics.
1. Launch ANSYS License Management Center
1.1 For Windows: Click Start>All Programs>ANSYS, Inc. License Manager> ANSYS License Management Center or copy and paste this http://localhost:1084/ to any web browser
1.2 For Linux: Run the start_lmcenter script in ansys_Inc/shared_files/licensing/ directory
2. Click Gather Diagnostic Information
3. Click SAVE TO FILE, the diagnostic folder will be created in the same directory as the “Download Location” set for the web browser that is used to open ANSYS License Management Center. If the web browser displays options between save and open, please save the file.
- The topic ‘Error when Installing License Manager’ is closed to new replies.
5674
1890
1419
