April 21, 2020 at 11:40 pm
shuegen
SubscriberI am attempting to run a temperature and total heat flux solution on a heat sink that I imported from Autodesk Inventor, but I am continuously, no matter which design or conditions I change, getting the same error: "An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide for more information."
Basically all I have done while attempting to evaluate this heat sink is first selecting the underside of the base of the heat sink, and adding a heat flow to it with a ramped magnitude of 13 W. Then I added a convection on the floor of the base (not the fins of the heat sink) with a film coefficient of 6e-6 (also ramped). Then I selected all sides of the fins and added another convection in the fins of 1.2e-5 (also ramped. The ambient temperature remained at 22 C. I do not understand what is going wrong here. I am not using the student version for this either as I am remote accessing the schools academic version of R19.0.
I have attached the log file for anybody that can help me with this problem. Thanks in advance!
April 22, 2020 at 6:21 pm
shuegen
SubscriberHas anybody possibly looked into this or have any insight as to what the problem could be. I have attempted changing the virtual memory and increasing it. I have changed the location that the files are saved in. I have tried changing the mesh and even the values that I have inserted. I still am getting the exact same issue and have no idea what to even try next in order to get this to function properly.Â
- The topic ‘Error Updating Cell-Solution in System Steady State Thermal’ is closed to new replies.
5864
