July 26, 2021 at 4:06 pm
LuisFig
SubscriberHello.
I am trying to make a cosimulation between Twin Builder (Simplorer) and Fluent. In the Simplorer, my Fluent component has 1 input and 1 output terminals that are connected to the terminals of a resistor (by a wire).
The Fluent component terminals are connected with the resistor through components called C2NC (conservative to Non-conservative), but I am not sure if this is right because when I analyze (run) the Simplorer, the following errors show up in the FLUENT:
July 27, 2021 at 1:52 pmJose Luis Gonzalez Hernandez
Ansys EmployeeHello For a co-simulation with Fluent and Twin Builder (and in general), Fluent needs to receive Real values and it sends back Real values to Twin Builder. In Twin builder, you need to define sensors and sources for this interaction.
The figure above is from the online help (Product Coupling - Fluent - Overview). The mass flow rate from the loop is measured using a sensor and the value is passed to the proper pin in Fluent, heat is supplied from a constant block. Fluent calculates the temperature and passes it to Twin Builder through a temperature source (using a pin).
I would recommend first creating a circuit with only the placeholders for the Fluent co-simulation pins (imagine the above diagram with the Fluent component removed and everything else the same), you could use constant blocks to mock the signals coming out of Fluent, and verify that your circuit works. Then, proceed to connect to Fluent.
Best Jose-Luis
September 23, 2021 at 4:28 amtolar
SubscriberHi.
How can one make the fluent receive real values from the sensor.??. ...I do have a circuit that logs data but I am concerned how this data can be used by fluent. Thank you
Viewing 2 reply threads- The topic ‘Error: Update_Time_Level: Invalid data & Error Object: #f’ is closed to new replies.
