April 22, 2021 at 7:12 am
GeoK
SubscriberHello, nI am currently using the 2020 R2 version of Ansys, and while trying to run fluent on a mesh I realized, which after verification seems good enough, I encounter the following error:Error:This is a post-processing only executablenError Object:#fnDo you know what it means, and how I can solve this ?Thank you -
April 22, 2021 at 8:44 am
Forum ModeratorCheck the launcher, you may have ticked the Pre/Post Only box in the General tab. n -
April 22, 2021 at 8:57 am
GeoK
SubscribernWhat do you mean by this ? nI am using the new Fluent Meshing version, so I'M doing Mesh -> Setup -> Solutionn -
April 22, 2021 at 9:23 am
GeoK
SubscriberAh indeed I found what you meant !Thank you for your answer n -
April 22, 2021 at 9:25 am
DrAmine
Ansys EmployeeGreat!n
Viewing 4 reply threads
- The topic ‘Error: This is a post-processing only executable’ is closed to new replies.
