ERROR: The element option SOLID185 was either not ordered with this ANSYS installation or…
January 6, 2022 at 2:19 pm
Ines_
SubscriberHi everyone!
I made a simple model with space claim, I meshed it and when performing structural analysis I get the following error:
"The element option SOLID185 was either not ordered with this ANSYS installation or the appropriate product was not selected for this session."
I have seen this error is because the ANSYS product license currently in use does not include the ability to use this element (/forum/discussion/5206/element-pipe289-error) but I have also checked that SOLID185 is commonly used in ANSYS so I don't get what might be the issue.
Any idea of what could be the source of the problem?
Thank you
January 7, 2022 at 11:08 amAshish Khemka
As you indicated above, it is due to licensing limitations.
Regards Ashish Khemka
January 18, 2022 at 8:52 amInes_
SubscriberHi Ashish,
Thank you for your answer.
It was. But not because of my license per se (as I thought at the beggining) but because someone else was using the license at the same time (and we only have one).
Hope this helps anyone.
In├®s
January 18, 2022 at 9:41 amErKo
That makes sense since - it is a standard element and we should have it.
Thanks for letting us know, and I also hope that this might be of help users experiencing a similar issue.
All the best for now
Erik
January 27, 2026 at 1:22 pmApril 25, 2026 at 12:15 amalfonso.ruizv
SubscriberÂ
I got the error for the SOLID185 too.Â
Initially it was a SOLID187 error, but I adjusted the mesh. it switched to this error.
I’m on a student license, but I think I should be able to use this, since I’m trying to complete a simulation excercise from the Structural Boundary Conditions Course
Viewing 5 reply threads- You must be logged in to reply to this topic.
6750
1324
1087
