July 30, 2024 at 8:12 am
July 30, 2024 at 12:47 pm
Devendra Badgujar
Forum ModeratorHello Roberto,Â
Is it when you open any specific file or doing any specific operation?Â
Can you please try clearing user settings clearing temp files? In the meantime will check if this is something known.Â
Thank you,
Devendra
July 30, 2024 at 1:20 pm
Roberto
SubscriberHello Devendra
The error occurs when starting the program, or while using
Regards
July 30, 2024 at 1:31 pm
Roberto
SubscriberBy temporary files do you mean the ones inside the app data path?C:\Users\Name\AppData\Roaming\SpaceClaim\DiscoverySpaceClaim23.2
July 30, 2024 at 1:57 pm
Devendra Badgujar
Which version and what language is set when using SpaceClaim?
Try resetting your options. These are kept in place even when uninstalling.
Go to File > SpaceClaim Options > Advanced > Reset All User Settings.
Try Deleting the contents of %appdata%\Local\SpaceClaim.
Devendra
August 1, 2024 at 6:37 am
Roberto
SubscriberHello, I solved the problem by deleting the temporary files and resetting the settings
Regards
August 1, 2024 at 6:39 am
Devendra Badgujar
Thanks for the update. Glad to know it worked.Â
Devendra
5729
