March 25, 2021 at 5:16 am
dhruvdeshwal17
SubscriberGreetings
This is an error I am facing while doing analysis.
The analysis - A copper plate and a magnet are placed adjacent to each other with a certain gap. A velocity is given to the plate (-0.1m/s) and the magnet remains stationary. So, as the plate move, the plate will see a change in a magnetic field by which eddy current will be generated in the plate and due to this current a magnetic field will be generated of opposite polarity as that of the magnet. Due to this generated magnetic field, the magnet experiences a force. I FMAGBC the copper plate and parallel flux as a boundary condition.
My aim is to calculate the eddy current, Lorentz force associated with this analysis, but I am not able to solve it.
Please provide any suggestion regarding loading, model, or anything you like to suggests
I am providing Marcos of my problem for a better understanding of the analysis.
/PREP7Â Â
!*Â Â
ET,1,SOLID97
!*Â Â
KEYOPT,1,1,1
KEYOPT,1,2,1
KEYOPT,1,5,1
!*Â Â
KEYOPT,1,1,1
!*Â Â
!Real Constants
R,1,
RMORE, , , , ,-0.1, , Â
RMORE, , , , , ,
!*Â Â
!*Â Â
R,2,
RMORE, , , , , , , Â
RMORE, , , , , ,
!*Â Â
! Material Properties Â
MPTEMP,,,,,,,, Â
MPTEMP,1,0Â Â
MPDATA,MURX,1,,1.2289Â Â ! Permeability of magnet
MPTEMP,,,,,,,, Â
MPTEMP,1,0Â Â
MPDATA,MGXX,1,,Â
MPDATA,MGYY,1,,Â
MPDATA,MGZZ,1,,9.26e5  !coercive force of magnet Â
MPTEMP,,,,,,,, Â
MPTEMP,1,0Â Â
MPDATA,MURX,2,,0.999Â Â ! Permeability of copper plate
MPTEMP,,,,,,,, Â
MPTEMP,1,0Â Â
MPDATA,RSVX,2,,1.72e-8 ! Resistivity of copper plateÂ
MPTEMP,,,,,,,, Â
MPTEMP,1,0Â Â
MPDATA,MURX,3,,1Â Â ! Permeability of air
! Modelling
BLOCK,-0.013,0.013,-0.013,0.013,-0.0025,0.0025, ! copper plate
CYLIND,0.013, ,0.0055,0.0355,0,360,  ! magnet
BLOCK,-0.05,0.05,-0.05,0.05,-0.05,0.05, ! enclosed area
FLST,2,3,6,ORDE,2Â Â
FITEM,2,1Â Â
FITEM,2,-3Â Â
VOVLAP,P51XÂ
FLST,2,3,6,ORDE,3Â Â
FITEM,2,1Â Â
FITEM,2,-2Â Â
FITEM,2,4Â Â
VGLUE,P51XÂ Â
/VIEW,1,1,1,1Â Â
/ANG,1Â Â
/REP,FASTÂ Â
NUMCMP,VOLU
! MeshingÂ
TYPE,  1 Â
MAT,    1
REAL,    2 Â
ESYS,    0 Â
SECNUM,Â
!*Â Â
MSHAPE,1,3DÂ
MSHKEY,0
!*Â Â
CM,_Y,VOLUÂ Â
VSEL, , , ,    2Â
CM,_Y1,VOLUÂ
CHKMSH,'VOLU'Â Â
CMSEL,S,_YÂ Â
!*Â Â
VMESH,_Y1Â Â
!*Â Â
CMDELE,_YÂ Â
CMDELE,_Y1Â Â
CMDELE,_Y2Â Â
!*Â Â
TYPE,  1 Â
MAT,    2
REAL,    1 Â
ESYS,    0 Â
SECNUM,Â
!*Â Â
CM,_Y,VOLUÂ Â
VSEL, , , ,    1Â
CM,_Y1,VOLUÂ
CHKMSH,'VOLU'Â Â
CMSEL,S,_YÂ Â
!*Â Â
VMESH,_Y1Â Â
!*Â Â
CMDELE,_YÂ Â
CMDELE,_Y1Â Â
CMDELE,_Y2Â Â
!*Â Â
TYPE,  1 Â
MAT,    3
REAL,    2 Â
ESYS,    0 Â
SECNUM,Â
!*Â Â
CM,_Y,VOLUÂ Â
VSEL, , , ,    3Â
CM,_Y1,VOLUÂ
CHKMSH,'VOLU'Â Â
CMSEL,S,_YÂ Â
!*Â Â
VMESH,_Y1Â Â
!*Â Â
CMDELE,_YÂ Â
CMDELE,_Y1Â Â
CMDELE,_Y2Â Â
!*Â Â
ALLSEL,ALL
! Force Flag
VSEL,S, , ,    1Â
ESLV,SÂ Â
CM,A,ELEMÂ Â
ALLSEL,ALLÂ Â
!*Â Â
!*Â Â
FMAGBC,'A'Â
! Boundary Condition
FLST,2,6,5,ORDE,2Â Â
FITEM,2,11Â Â
FITEM,2,-16Â
DA,P51X,ASYM
FINISHÂ Â
/SOL
! Tranisent Velocity
!*Â Â
ANTYPE,4
!*Â Â
TRNOPT,FULLÂ
!*Â Â
DELTIM,0.002,0,0
OUTRES,ERASE
OUTRES,ALL,ALLÂ Â
AUTOTS,1
TIME,0.01Â Â
/STATUS,SOLU
SOLVEÂ Â
Thank You!
March 25, 2021 at 1:14 pmNKC
Forum ModeratornWhich Ansys tool are you using for this simulation?.RegardsnNavya?nMarch 25, 2021 at 1:41 pmdhruvdeshwal17
SubscriberHellonANSYS APDL 16.0 (Academic Research)nRegardsnMarch 26, 2021 at 8:52 amErKo
Ansys EmployeeThis element is no longer supported - use current elements like solid226.nSee example for more info:nhelp/ans_lof/lof2Dstatmaganalexamples.html#d0e5425nIn low-freq. emag chapter:nn2.5.3. Example: 2-D Static Magnetic Analysis with Velocity EffectsnnHope this helpsnnEriknnMarch 26, 2021 at 9:43 amdhruvdeshwal17
SubscriberThank You!nViewing 4 reply threads- The topic ‘***ERROR*** Resistivity must be input for velocity effect in elements’ is closed to new replies.
5879
1306
