February 14, 2024 at 2:06 pm
maulikkumarchaudhary21
SubscriberI am a beginner in Ansys Workbench but I faced some errors in simple analysis of beam but being a newbie I am unable to understand the error, So It would be helpful if you help me sort it out as I don't get what is wrong.
HERE"S THE COPIED TEXT FROM THE SOLVER OUTPUT!
 2024 R1
 Point Releases and Patches installed: Â
 Discovery 2024 R1 Â
 Fluids 2024 R1Â
 Ansys Dynamic Reporting 2024 R1
 SpaceClaim 2024 R1Â
 CFX (includes CFD-Post) 2024 R1
 Chemkin 2024 R1
 EnSight 2024 R1
 FENSAP-ICE 2024 R1Â
 Fluent (includes CFD-Post) 2024 R1Â
 Polyflow (includes CFD-Post) 2024 R1
 Forte (includes EnSight) 2024 R1
 TurboGrid 2024 R1 Â
 ACIS Geometry Interface 2024 R1
 AutoCAD Geometry Interface 2024 R1Â
 Catia, Version 4 Geometry Interface 2024 R1
 Catia, Version 5 Geometry Interface 2024 R1
 Catia, Version 6 Geometry Interface 2024 R1
 Creo Elements/Direct Modeling Geometry Interface 2024 R1
 Creo Parametric Geometry Interface 2024 R1Â
 Inventor Geometry Interface 2024 R1
 JTOpen Geometry Interface 2024 R1 Â
 NX Geometry Interface 2024 R1 Â
 Parasolid Geometry Interface 2024 R1 Â
 Solid Edge Geometry Interface 2024 R1 Â
 SOLIDWORKS Geometry Interface 2024 R1 Â
 Speos 2024 R1 Â
 Aqwa 2024 R1
 Autodyn 2024 R1
 Material Calibration App 2024 R1
 Customization Files for User Programmable Features 2024 R1Â
 Mechanical Products 2024 R1
 Motion 2024 R1Â
 Academic Student 2024 R1
         ***** MAPDL COMMAND LINE ARGUMENTS *****
 BATCH MODE REQUESTED (-b)   = NOLIST
 INPUT FILE COPY MODE (-c)   = COPY
 DISTRIBUTED MEMORY PARALLEL REQUESTED
      2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS (FORCED)
   TOTAL OF    2 CORES REQUESTED
 INPUT FILE NAME             = C:\Users\mauli\AppData\Local\Temp\WB_mauli_16884_2\_ProjectScratch\Scr610C\dummy.dat
 OUTPUT FILE NAME            = C:\Users\mauli\AppData\Local\Temp\WB_mauli_16884_2\_ProjectScratch\Scr610C\solve.out
 START-UP FILE MODE          = NOREAD
 STOP FILE MODE              = NOREAD
 GPU ACCELERATOR OPTION REQUESTED
    1 GPU ACCELERATOR DEVICES REQUESTED
 RELEASE= 2024 R1             BUILD= 24.1     UP20231106  VERSION=WINDOWS x64
 CURRENT JOBNAME=file0 19:04:21 FEB 14, 2024 CP=     0.000
 *** FATAL ***                          CP =      0.031  TIME= 19:04:21
 No recommended GPU devices have been detected on machine              Â
 THEHPPavillion. For optimal performance, install a recommended GPU   Â
 device in this machine. If you wish to use an alternative GPU device,Â
 please review the recommendations in the section titled "Requirements Â
 for the GPU Accelerator in Mechanical APDL" in the Installation Guide Â
 for your platform.                                                    Â
 The above error is non-recoverable by ANSYS                           Â
 ANSYS run terminated by the indicated error                          Â
 Current data base saved if possible.                                 Â
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2024 R1Â Â Â Â Â Â Â Â Â Â Â Build: 24.1Â Â Â Â Â Â Update: UP20231106Â Â Platform: WINDOWS x64
Date Run: 02/14/2024Â Â Time: 19:04Â Â Â Â Process ID: 16444
Operating System: Windows 11Â (Build: 22631)
Processor Model: AMD Ryzen 5 5600H with Radeon Graphics
Compiler: Intel(R) Fortran Compiler Classic Version 2021.9Â (Build: 20230302)
         Intel(R) C/C++ Compiler Classic Version 2021.9 (Build: 20230302)
         Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
         BLAS Library supplied by AMD BLIS
Number of processes requested          :   2
Number of threads per process requested :Â Â Â 1
Total number of cores requested        :   2 (Distributed Memory Parallel)             Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.10 for Windows* OS
Number of GPUs requested               :   1
GPU Acceleration: NVIDIA Library Requested but not Enabled
GPU Device with ID =Â 0 is: NVIDIA GeForce GTX 1650
GPU Driver Version: 12.30
CUDA Version: 12.0
Job Name: file0
Input File: dummy.dat
 Core               Machine Name  Working Directory
    0             THEHPPavillion  C:\Users\mauli\AppData\Local\Temp\WB_mauli_16884_2\_ProjectScratch\Scr610C
    1             THEHPPavillion  C:\Users\mauli\AppData\Local\Temp\WB_mauli_16884_2\_ProjectScratch\Scr610C
Total CPU time for main thread                   :       0.1 seconds
Total CPU time summed for all threads            :       0.0 seconds
Elapsed time spent obtaining a license           :       0.3 seconds
Elapsed time spent pre-processing model (/PREP7)Â :Â Â Â Â Â Â Â 0.0 seconds
Elapsed time spent solution - preprocessing      :       0.0 seconds
Elapsed time spent computing solution            :       0.0 seconds
Elapsed time spent solution - postprocessing     :       0.0 seconds
Elapsed time spent post-processing model (/POST1) :Â Â Â Â Â Â Â 0.0 seconds
+------------------ E N DÂ Â M A P D LÂ Â S T A T I S T I C S -------------------+ -
February 15, 2024 at 9:17 am
Aniket Chavan
Forum ModeratorYou seem to be using Graphics acceleration from GPU. It is only supported with GPUs mentioned here:
https://www.ansys.com/content/dam/it-solutions/platform-support/2024-r1/ansys-2024-r1-gpu-accelerator-capabilities.pdf
You should either turn off GPU acceleration from where you have turned it on, i.e. from solver process settings (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_using_solve_handlers.html)
or you can use ANSGPU_OVERRIDE variable as mentioned in (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/installation/win_gpureqt.html)-Aniket
February 15, 2024 at 10:57 am
SubscriberThank you Aniket, It's solved successfully!
- The topic ‘Error related to gpu’ is closed to new replies.
6510
