December 3, 2021 at 3:08 pm
Andrea Ventura
? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHello, a customer reported this error. As you can see in the image the unfolded part (on the right) is ok, but in the drawing sheet is flipped, but the angle dimension still remains +90°. The right beahaviur is have the same results, even a flipped part with the opposite angle -90° is correct, but not a flipped unfolded part and a wrong angle, the employee who bends the part produce a wrong part and there's a waste of material for this error. This isn't the first bug report about this issue. It's very important have a reliable process in order to avoid to produce wrong part with waste of money and time. Please, solve this problem urgently! -
December 3, 2021 at 3:45 pm
Devendra Badgujar
Forum ModeratorHello DrkAngl
Let me look into this and get back to you.
December 3, 2021 at 3:49 pm
Andrea Ventura
SubscriberThanks
December 3, 2021 at 4:24 pm
Roberto
SubscriberDrkAngl HelloÂ
What version of Spaceclaim are you using?
Regards
December 3, 2021 at 4:29 pm
Andrea Ventura
Subscriber2021.2, but I seen the same problem with older version.
December 6, 2021 at 7:55 am
Roberto
SubscriberHello
the problem I had on 2 previous versions in this one no problem
Regards
December 6, 2021 at 8:45 am
Devendra Badgujar
IÂ checked the model file and was able to reproduce some of it. The issue of flipped unfolded part in the drawing sheet is the known behavior but there seems to be no error on my end related to the angle.
I will raise a bug for the issue with the developers and will update you once I get any more information on this.
Regards.
January 3, 2022 at 7:50 am
Devendra Badgujar
Bug ( 559657 ) has been filed for this issue and will get back to you once I get an update.
Regards.
April 21, 2022 at 1:40 pm
Andrea Ventura
Subscriberany news about fix?
April 21, 2022 at 1:55 pm
Andrea Ventura
SubscriberI have again the same bug report. Wrong unfolded calculation. The unfolded shape should be mirrored. If I bend with this angle and this shape I'll get wrong part. If I use internal face I get the error, if I use external one not.
? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
April 21, 2022 at 2:07 pm
Devendra Badgujar
Forum ModeratorHi DrkAngl
The development team is working on it. I have not heard back from them on this.
I will check and let you know.
Regards.
November 14, 2022 at 5:39 am
November 23, 2022 at 4:51 am
paul pladet
SubscriberDevendra Badgujar Could you please have a look at the problem above aswell?
November 23, 2022 at 5:01 am
Devendra Badgujar
Forum ModeratorPaescÂ
This seems like the same issue as the one above where it is a drawing issue - UP/DOWN is relative to unfold plane and not related to drawing view's plane.Â
I will check this case and will get back to you.Â
November 30, 2022 at 9:38 am
Andrea Ventura
SubscriberDevendra Badgujar Any news about this problem? Now is solved with the upcoming version? Customers are angry to waste material due to software problem.
November 30, 2022 at 9:52 am
Devendra Badgujar
Forum ModeratorDrkAnglÂ
For this problem, it is a drawing issue - UP/DOWN is relative to unfold plane and not related to drawing view's plane.
We are looking into these features in the future releases in Discovery. We do not yet have a timeline for it. We will let you know when we learn more in the coming months. Thank you!
Regards.
January 18, 2023 at 5:23 am
Roberto
SubscriberDevendra Badgujar This problem is important to solve
January 17, 2023 at 8:57 am
- The topic ‘Error on drawing sheet for an unfolded part’ is closed to new replies.
5694
1891
1419
