July 4, 2018 at 1:53 pm
ufficiotecnico
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions* Rebuilt URL to: https://ansys-fno.flexnetoperations.com/
*Â Â Trying 64.14.29.39...
* TCP_NODELAY set
* Connected to ansys-fno.flexnetoperations.com (64.14.29.39) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*Â Â CAfile: C:tmpca-bundle.crt
 CApath: none
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / AES256-SHA256
* ALPN, server accepted to use http/1.1
* Server certificate:
*Â subject: C=US; ST=IL; L=Itasca; O=Flexera Software LLC; OU=Prod IT; CN=*.flexnetoperations.com
* start date: Jan 4 00:00:00 2018 GMT
* expire date: Jan 9 12:00:00 2020 GMT
*Â subjectAltName: host "ansys-fno.flexnetoperations.com" matched cert's "*.flexnetoperations.com"
*Â issuer: C=US; O=DigiCert Inc; CN=DigiCert SHA2 Secure Server CA
*Â SSL certificate verify ok.
> GET / HTTP/1.1
> Host: ansys-fno.flexnetoperations.com
> User-Agent: curl/7.53.1
> Accept: */*
< HTTP/1.1 403 Forbidden
< Date: Wed, 04 Jul 2018 12:59:20 GMT
< Server: Apache
< Content-Length: 21
< Content-Type: text/html; charset=iso-8859-1
< Set-Cookie: NSC_10.100.1.39_GOPXFC_443=14b5a3d94e3ccba681f7b2ff48ee03d4bb9c24581b8369761478e63378ce464c06e23611;path=/;secure;httponly
Error 403 - Forbidden* Connection #0 to host ansys-fno.flexnetoperations.com left intactC:tmp>
July 5, 2018 at 5:12 am
Naresh Patre
Ansys EmployeeHello Alfa Inox Thanks for sending the details. I am looking into it and will get back to you.
July 5, 2018 at 6:45 am
Roberto
SubscriberHi Naresh,
thank you we hope to understand what is the cause to solve
Regards -
November 21, 2019 at 1:30 pm
Sander van Doesburg
Subscriberwhat was the fix? i've the same error in my curl output.
May 14, 2020 at 6:30 pm
Naresh Patre
Ansys Employeesuggested manual activation through command prompt
- The topic ‘error license’ is closed to new replies.
6039
