June 23, 2021 at 8:57 pm
mohamad
SubscriberHello,
I'm trying to use journal file for HPC but i have an error.
what can i do for fix it?
journal file:
parallel/partition/auto/use-case-file-method yes
file/read-case case144.cas
define/user-defined/interpreted-functions "case14.c" "cpp" 10000 no
parallel/partition/print
solve/report-definitions add report12 volume-average field liquid-fraction zone-names (pcm) quit
solve/report-files add liquidfile frequency 1 report-defs (liquid-file) quit
solve/report-plots add liquid-plot report-defs (liquid-plot) quit
solve/initialize/initialize-flow
file/auto-save/data-frequency flow-time 1
file/auto-save/append-file-name-with flow-time 1
solve/set/time-step 1e-1
solve/dual-time-iterate 10 30
solve/reporting-interval 30
file/confirm-overwrite no
file/write-data case144.dat.gz
exit yes
Error:
> solve/report-files add liquidfile frequency 1 report-defs (liquid-file)Invalid report definition quit
Report Definitions(1) [()] solve/report-plots Invalid report definition
add Invalid report definition
liquid-plot Invalid report definition
report-defs Invalid report definition
(liquid-plot)Invalid report definition
quit
will be very appreciated by your help. Thank you in advance.
June 24, 2021 at 6:07 amDrAmine
Ansys EmployeeLine by line you need to debug where it starts getting the issue. It seems related to the report definition and file. Probably using the wrong report definition name.
June 24, 2021 at 9:49 amRob
Forum ModeratorAlways start the command line with / too ie
/file/read-case case144.cas
otherwise you are relying on the commands to return to the root level every time.
What is the "quit" command for? To terminate a list use () ie open & closed brackets with no space between them.
Viewing 2 reply threads- The topic ‘error in journal file (on HPC)’ is closed to new replies.
5844
