August 29, 2025 at 9:09 am
jahn.reichmann
SubscriberHi,
I'm unable to import any geometry from discovery (.dsco-file) to the fluent mesher. I have tried many geometries, updated my graphic driver, reinstalled Ansys and tried to find possible causes in the working path of the ansys files... The same error all again. I'm able to import .step-files though. Can anyone help me please?
This is the error:
Error: Timeout reached, failed to start Discovery!
Error Object: ("cadSession_e8421058_3637_4cbb_9f27_af2c98aba4d2.open_session('dsco')")
ERROR:root: no element found: line 61, column 0
Error: Error in CAD Import
Error occurred during import.
Error Object: #f
Error: state/object/execute-command:Exception encountered in S_ExecuteTask: Error in CAD Import
Thank you in advance! -
September 2, 2025 at 7:56 am
Essence
Ansys EmployeeHello,
Did you try using other formats (.STEP, .scdoc, etc.) just to be sure?
September 19, 2025 at 6:46 pm
sebastian.lazalde
SubscriberHello, I'm having exactly the same error. Don't know what's happening. My document is .scdoc. Here's my log:Â
Error Object: ("cadSession_df0bb8a0_3494_4022_a6f7_eb2e3f6969e2.open_session('scdoc')")
Importing one geom object per program-controlled and one zone per body ...
C:\Program Files\ANSYS Inc\ANSYS Student\v252\commonfiles\CPython\3_10\winx64\Release\python\..\Ansys\TGrid\CADReaders.py started by Sebastian Lazalde on DESKTOP-SLZ00K22 winx64 on Fri Sep 19 12:40:41 2025
using Python 3.10.16 (remotes/origin/14d18b8e2626165312e076b70cf60f0faa8db8d5-dirty:14d18b8e, May 20 2) [MSC v.1942 64 bit (AMD64)]
using Ansys.Meshing.FieldMesher build Jun 13 2025 15:24:50
An internal error occured. Please report all the output from the program,
including the above traceback, to ANSYS.
Importing the selected file(s) could not be completed. Check to make sure that the selected file format is supported. In addition, check to make sure the CAD Readers are properly configured for the format using the CAD Configuration Manager utility.
Error Object: #f
Error Object: #f
Error Object: ()
Error: An error or interrupt occurred in the previous operation.
Details have been printed to the text console transcript.
Error Object: #f
Could you provide me some guidance?Â
6745
1324
1047
