February 19, 2021 at 5:43 am
Bharath_Bharadwaj
SubscriberI am trying to import a space claim file into Fluent in the Fault-tolerant workflow,nAs I click on Load or Update etc. after selecting the file, I get the following error message.nnAs a background, the scdoc was created by importing STLs with appropriate named selections.nnCould someone please help,nThank you!nBharathn----nError message in ConsolenC:\Users\bharathrb.ROOP-21B\Desktop\Current\021921\Trial1_files\dp0\FLTG\Fluent>C:\Program Files\ANSYS Inc\v202/scdm/SpaceClaim.exe /headless=true /Splash=False /WELCOME=false /CommandLineAddInsOnly=true /ADDINMANIFESTFILE=C:\Program Files\ANSYS Inc\v202/scdm/ConversionAddInXml.txt /EXECUTECOMMAND=ConversionAddIn.ConvertnStatus1:ConverterInput161371206113484:C:/Users/bharathrb.ROOP-21B/Desktop/Current/021921/Minichannel.scdocn2/19/2021 12:16:05 AMError2:ConverterInput161371206113484:C:/Users/bharathrb.ROOP-21B/Desktop/Current/021921/Minichannel.scdocnnError: FMD conversion of C:/Users/bharathrb.ROOP-21B/Desktop/Current/021921/Minichannel.scdoc has failed!nError Object: #fn -
February 19, 2021 at 3:08 pm
RK
Ansys EmployeeHello, nFirst, make sure there are no geometry errors. In SC, right click on the component and check geometry. If no errors, try saving the geometry as tgf and then load the tgf file in Fluent meshing. Let me know if this works. n -
February 19, 2021 at 3:55 pm
Bharath_Bharadwaj
SubscriberHello, Thanks for your reply, When I check geometry in space claim there are no geometry errors.nHowever when I try saving the file as a .tgf, I get thisnFacets in Group Fluid_Interface are already contained in Group Fluid_Outlet. Make sure that any facet or edge is not contained in more than one group.nI believe some facets are common. However, I tried multiple times to select the facets carefully so that they are not in two different named selections.nAs i am dealing with huge STLs, it is hard to select individual facets.nIs there a way to make sure that facets in one named selection are not selected while choosing facets for another (or perhaps looking at intersecting facets in the named selections and resolving them.)nnAs a background, i select the faces from an STL imported into fluent and adjust the sensitivity on selected faces to adjust the number of selected facets (triangles here) to create a named selection for inlets, outlets, etc.n
- The topic ‘Error importing Space Claim File into Fluent (.scdoc)’ is closed to new replies.
1324
1047
