May 30, 2024 at 11:25 am
June 4, 2024 at 2:17 pm
Rabindra Paul
Ansys EmployeeHi William,
Thanks for asking question in this forum. Can you check with a workshop IDF file. It could be related to IDF format. If workshop IDF works then you may compare the format of your IDF and workshop IDF. If you need workshop IDF file, please create a support request in Ansys Customer Portal.Â
Hope this helps.Â
Rabindra
June 4, 2024 at 2:29 pm
Rabindra Paul
Ansys EmployeeWilliam, Based on the error message, you may also edit the THOU to $THOU and see whether that is the reason. If not please try the other suggestion in my previous reply.
Rabindra
- The topic ‘Error importing PCB file in Icepak’ is closed to new replies.
