Error – Fluent solver – Floating point exception – Divergence detected
    • nagasudhan
      When I tried creating solidification/melting model for phase change materials(PCMs) , I ended up with following error message
      Boundary conditions used:
      1. Inlet - Mass-flow inlet - 3kg/s, Temp - 363K
      2. outlet - pressure outlet - 101325 pa (gauge pressure)
      Material property:
      1. PCM solidus temp, liquidus temp : 494 K, 511K
      2. Water: Fluent default
      Error message:
      ter continuity x-velocity y-velocity z-velocity energy time/iter
      32 1.7098e+09 4.6928e-01 1.8290e-01 3.1616e-01 1.6942e-04 0:00:12 1
      Stabilizing temperature to enhance linear solver robustness.
      Stabilizing temperature using GMRES to enhance linear solver robustness.
      temperature limited to 1.000000e+00 in 1013 cells on zone 7 in domain 1
      temperature limited to 5.000000e+03 in 5428 cells on zone 7 in domain 1
      temperature limited to 1.000000e+00 in 23995 cells on zone 6 in domain 1
      temperature limited to 5.000000e+03 in 38774 cells on zone 6 in domain 1
      Reversed flow on 67 faces (67.6% area) of pressure-outlet 10.
      (update-animation-object "animation-1")()
      Flow time = 33s, time step = 33
      167 more time steps
      Updating solution at time level N...
      done.
      iter continuity x-velocity y-velocity z-velocity energy time/iter
      33 2.4241e+11 4.9479e-01 1.9709e-01 2.6575e-01 1.5073e-01 0:142 1
      Stabilizing x-momentum to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature
      Reversed flow on 52 faces (53.6% area) of pressure-outlet 10.
      Error at host: floating point exception
      Error at Node 0: floating point exception
      Error at Node 1: floating point exception
      Error at Node 2: floating point exception
      Error at Node 3: floating point exception
      Compute processes interrupted. Processing can be resumed.
      Error: floating point exception
      Calculation complete.
      Attached images showing Liquid - fraction of PCM balls
    • nagasudhan
    • RK
      What is the courant number you have specified? Are you using "Higher Order Term Relaxation" option?
      Rahul
    • nagasudhan
      I didn't specify any courant number, it should be default and relaxations factors are assigned by fluent, I have attached a screenshot below.
      Relaxation method - Gauss seidel
      To rephrase Rahul's question. For the given time step, what is the Courant Number?
    • nagasudhan
      Courant number is set default. It is 500 for this case
      Solver setup is coupled.
Viewing 5 reply threads
  • The topic ‘Error – Fluent solver – Floating point exception – Divergence detected’ is closed to new replies.
