Ansys Products
Ansys Products
Error Flexlm server is not responding : GRANT Edupack 2021 R1.202
    • FrBrenno
      For my materials science course, my professor provided us a license of Granta Edupack 2021 R1.202 and all instruction to install and activate it. An assignment planned for the end of May must include information got from your software. However, I followed all the instructions given for the installation and the software is not opening.
      How I am not in the university network, I connect in it by a VPN, which is working correctly. As it was said on the instructions, the VPN must be activate before running the software. The Granta Edupack gives the following error window :
    • Matt Madore
      Array can you please open Windows Powershell and run this command? Replace "servername" with the actual servername of the license server. Share the output. You can block out the name if you prefer.
      Test-NetConnection servername -Port 1055
      If this fails, there is a problem accessing the license server over the VPN. If this is successful then this could be failure due to the dynamic port for ansyslmd which will need to be set to a static port by the IT team. They also need to ensure license communications can get through any VPN firewalls.
    • FNCvanE
      I am having the same problem. When I use this command in Powershell is says false. But with what do I have to replace the servername with? When I try to replace it with the VPN I got from my school it doesn't work.
    • Matt Madore
      FNCvanE "servername" would the the name of the license server that you are trying to connect to, it would be the name shown in the error message.
  • The topic ‘Error Flexlm server is not responding : GRANT Edupack 2021 R1.202’ is closed to new replies.
