January 15, 2019 at 3:57 pm
JPernosky
SubscriberHello,
I am having an error during the installation process of the Student v19.2 ANSYS software.
After extracting all the files from the .zip file download, I run the setup as an administrator as advised, but once I decide a location for the setup to install the software and start the install process, I am faced with this error message: "The manifest file specified for this installation does not exist. Please verify that the install was run according to documentation. File not found: uninst_data.dat". A picture is attached.
I am pretty certain I have run according to documentation, and I have re-downloaded and gone through this process about 5 times to no avail. I have even done some troubleshooting by looking at other discussions on this topic (/forum/forums/topic/file-not-found-uninst_data-dat-1/); however, they appeared to be able to solve the issue by re-downloading the software, but that has not worked for me so far.
Any suggestions? I need to download this software for a course I am taking right now, and I am losing hope for a solution.
Thank you in advance!
January 15, 2019 at 8:02 pm
tsiriaks
Ansys EmployeeI wonder if you have all the permissions on both installation directory and the installation package directory. Could you let us know the directories for these two ?
Thanks,
Win
January 16, 2019 at 7:42 pm
ANSYS_MMadore
Forum ModeratorCould you provide the contents of this file? If it shows a size of 0kb, try deleting it and then run your install again.
%APPDATA%Ansysv192ProdConfiguninstall_data.data file?
Thank you,
Matt -
January 16, 2019 at 8:08 pm
JPernosky
SubscriberHi mmadore,
The file "uninst_data.dat" appeared to have a file size of 0kb. I deleted it, and I am currently running the install again. It appears to be running smoothly without error at the time being.
I will update once the install has run through its entire process whether or not it worked completely.
Thanks!
November 6, 2019 at 4:21 am
syera
Subscriberhai.. may i know why the file is not found when i want to download through ANSYS STUDENT ?
Thanks for your consideration!
November 8, 2019 at 11:27 pm
tsiriaks
Ansys EmployeeThe install gets tricked that the file doesn't exist but in fact, it exists with 0 kb size. So, the fix is to just remove the file
%APPDATA%Ansysv1##ProdConfiguninstall_data.data
so that the installer will start over again.
April 6, 2020 at 4:28 am
April 7, 2020 at 12:26 am
tsiriaks
Ansys EmployeeThis is a different issue. Please create a new thread. Also, let us know what happens if you click 'yes'
October 26, 2023 at 2:27 pm
Sayed Usman
SubscriberSame problem with nee also please make a video of this uninst_data error so that it can be helpful to students
- The topic ‘ERROR- “File not found: uninst_data.dat”’ is closed to new replies.
5289
1885
1403
1267
