October 29, 2024 at 5:41 pm
Samara Caetano
SubscriberHi community,
I’m facing the following error when I try to extract beams for a Baja SAE analysis in SpaceClaim: “failed to extract 1 beam”, even if I try to extract all the beams or just 1. I tried using a .STEP file and Parasolid as well, but either one worked. What could be causing this error?
October 30, 2024 at 10:13 am
Deepak
Ansys EmployeeHi,
I followed the video in the course module: BAJA SAE Chassis Analysis | Ansys Innovation Courses. It works fine, so not sure what error is there. Please check for split edges or other geometry issues.
Try to download this project files from here:
Thanks,
Deepak
