November 5, 2020 at 3:08 pm
Potts
SubscriberHello,nnI am attempting to learn Fluent to try some work from home simulations. Having some issues import elbow.scdoc into fluent 2020 R...nnError: Error in CAD ImportnError Object: #fnError: Error occurred during import.nError Object: #fnError: Importing the selected file could not be completed. Check to make sure that the selected file format is supported. In addition, check to make sure the CAD Readers are properly configured for the format using the CAD Configuration Manager utility.nError Object: #fnnAny help would be great! I have tried moving the working directory to a different location (it was on OneDrive) and my file now is the full path. Very Strange?nThank younp.s. its the acadmic student versionn -
November 5, 2020 at 3:09 pm
Potts
Subscribernn -
November 6, 2020 at 3:17 am
Keyur Kanade
Ansys EmployeeCan you please open it in Workbench and then connect geometry to Meshing or Fluent with meshing. nAre you able to import that geometry in meshing? nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help links -
November 6, 2020 at 3:18 am
Keyur Kanade
Ansys EmployeePlease also search forum where you will get lot of posts about importing geometry. -
November 10, 2020 at 12:02 pm
Potts
SubscriberThank you for the help.nI will check the rest of the forum before submitting again.nBest regards, Pottsn -
November 10, 2020 at 2:09 pm
November 10, 2020 at 2:32 pm
Forum ModeratorPlease can you post some images of the geometry? n -
November 10, 2020 at 2:45 pm
Potts
SubscriberHi, It is the geometry outlined in this tutorial video. https://www.youtube.com/watch?v=rFQisXCwLXI&t=10s nHere is my copy: n
n
November 10, 2020 at 3:17 pm
Forum ModeratorOdd, have you configured the CAD readers? It's an option in Start-Ansys2020-CAD Confign -
November 10, 2020 at 3:28 pm
Potts
SubscriberI would have assumed spaceclaim would automatically work with fluent?nif not there doesn't seem to be a Spaceclaim R2 2020 option in the CAD Confign -
November 10, 2020 at 3:47 pm
Viewing 10 reply threads
- The topic ‘Error: Error in CAD Import HELP?’ is closed to new replies.
1587
1386
1242
