April 17, 2024 at 6:57 pm
Rescale Support
SubscriberHello! I need help to get some steps to solve a problem during a restart. I'm trying to replicate the example of an earthquake analysis of a dam provided here: https://lsdyna.ansys.com/dams/
I organized the example files in separate directories and followed these steps (as described in the example README file):
1. Run dam-static.k 2. Run dam-auxiliary.k 3. Copy stat.d3dump01 from the static run (stat.d3full01 for MPP), and aux.gmbin from the dynamic run, into a separate directory for transient analysis. 4. Run dam-transient.k
I'm running on a small Linux machine, with ANSYS 2023 R2, and these are the commands I used:cd 01static
lsdyna -dis -np 8 i=dam-static.k jobid=stat
cd ..
cp 00motion/* 02aux/. ## 00motion contains the ground motion files
cp 00motion/* 03trans/.
cd 02aux/
lsdyna -dis -np 8 i=dam-auxiliary.k jobid=aux
cd ../03trans
cp ../01static/stat.d3dump* .
cp ../02aux/aux.gmbin .
lsdyna -dis -np 8 i=dam-transient.k r=stat.d3dump01 gminp=aux.gmbin jobid=trnThe error I get is as follows:
*** Error 10871 (KEY+871) For small deck restart, need to add *CHANGE_CURVE_DEFINITION for curve id 1 in the restart input file E r r o r t e r m i n a t i o nI could not figure out or find information on how to modify the files to include the *CHANGE_CURVE_DEFINITION keyword and what syntax to use.Â
Any steps to help solve the issue are welcome.Â
Thanks.Â--Roque Lopez
Rescale team. -
April 17, 2024 at 7:27 pm
Ushnish Basu
Ansys EmployeeI believe you are using MPP, so please use "n=stat.d3full01" as indicated in the comments in the input files
April 17, 2024 at 8:07 pm
Rescale Support
SubscriberThanks, Ushnish!Â
I confirm that the static and auxiliary analyses run fine. No errors.Â
I tried with stat.d3full01, too. The error is different:Â *** Error 70008 (OTH+8)
   restart file does not exist
 ./stat.d3full01.0000
 E r r o r  t e r m i n a t i o nThe 'stat.d3full01.0000' file does not exist.
Here are the contents of my work directory:
$ treeÂ
├── 00motion
│  ├── elcentro-x.ath
│  ├── elcentro-y.ath
│  └── elcentro-z.ath
├── 01static
│  ├── dam-static.k
│  ├── host.list
│  ├── mpd.hosts
│  ├── stat.adptmp
│  ├── stat.bg_switch
│  ├── stat.d3dump01.0000
│  ├── stat.d3dump01.0001
│  ├── stat.d3dump01.0002
│  ├── stat.d3dump01.0003
│  ├── stat.d3dump01.0004
│  ├── stat.d3dump01.0005
│  ├── stat.d3dump01.0006
│  ├── stat.d3dump01.0007
│  ├── stat.d3full01
│  ├── stat.d3hsp
│  ├── stat.d3plot
│  ├── stat.d3plot01
│  ├── stat.d3plot02
│  ├── stat.d3plot03
│  ├── stat.d3plot04
│  ├── stat.d3plot05
│  ├── stat.d3plot06
│  ├── stat.group_file
│  ├── stat.kill_by_pid
│  ├── stat.load_profile.csv
│  ├── stat.load_profile.xy
│  ├── stat.mes0000
│  ├── stat.mes0001
│  ├── stat.mes0002
│  ├── stat.mes0003
│  ├── stat.mes0004
│  ├── stat.mes0005
│  ├── stat.mes0006
│  ├── stat.mes0007
│  └── stat.status.out
├── 02aux
│  ├── aux.adptmp
│  ├── aux.bg_switch
│  ├── aux.d3dump01.0000
│  ├── aux.d3dump01.0001
│  ├── aux.d3dump01.0002
│  ├── aux.d3dump01.0003
│  ├── aux.d3dump01.0004
│  ├── aux.d3dump01.0005
│  ├── aux.d3dump01.0006
│  ├── aux.d3dump01.0007
│  ├── aux.d3full01
│  ├── aux.d3hsp
│  ├── aux.d3plot
│  ├── aux.d3plot01
│  ├── aux.d3plot02
│  ├── aux.d3plot03
│  ├── aux.d3plot04
│  ├── aux.d3plot05
│  ├── aux.d3plot06
│  ├── aux.d3plot07
│  ├── aux.d3plot08
│  ├── aux.d3plot09
│  ├── aux.d3plot10
│  ├── aux.d3plot11
│  ├── aux.d3plot12
│  ├── aux.d3plot13
│  ├── aux.d3plot14
│  ├── aux.d3plot15
│  ├── aux.d3plot16
│  ├── aux.d3plot17
│  ├── aux.d3plot18
│  ├── aux.d3plot19
│  ├── aux.d3plot20
│  ├── aux.d3plot21
│  ├── aux.d3plot22
│  ├── aux.d3plot23
│  ├── aux.d3plot24
│  ├── aux.d3plot25
│  ├── aux.d3plot26
│  ├── aux.d3plot27
│  ├── aux.d3plot28
│  ├── aux.d3plot29
│  ├── aux.d3plot30
│  ├── aux.d3plot31
│  ├── aux.gmbin
│  ├── aux.kill_by_pid
│  ├── aux.load_profile.csv
│  ├── aux.load_profile.xy
│  ├── aux.mes0000
│  ├── aux.mes0001
│  ├── aux.mes0002
│  ├── aux.mes0003
│  ├── aux.mes0004
│  ├── aux.mes0005
│  ├── aux.mes0006
│  ├── aux.mes0007
│  ├── aux.status.out
│  ├── dam-auxiliary.k
│  ├── elcentro-z.ath
│  ├── host.list
│  └── mpd.hosts
├── 03trans
│  ├── aux.gmbin
│  ├── dam-transient.k
│  ├── fort.13
│  ├── fort.59
│  ├── host.list
│  ├── mpd.hosts
│  └── stat.d3full01
├── README.dams
└── tmpÂ
April 17, 2024 at 8:38 pm
Tonmoy
SubscriberHello Roque,
The problems, as Dr. Basu has pointed out, are occurring due to the use of MPP. Change the last terminal command from
tolsdyna -dis -np 8 i=dam-transient.k n=stat.d3full01 gminp=aux.gmbin jobid=trn
and I can confirm that it will work like a charm. The parameter
ntakes the restart input for MPP instead of the traditionalrused for SMP.- Tonmoy.
April 17, 2024 at 9:05 pm
Rescale Support
SubscriberAh! Thanks again Dr. Ushnish Basu and Tonmoy!Â
I realize I missed the parameterÂn in the command example. I tried it and it's working now.Â
Thanks again for the speedy help!Â
- The topic ‘Error during restart of dam analysis example’ is closed to new replies.
5664
1890
1414
1304
