August 6, 2021 at 2:54 pm
vmurthy1
SubscriberAugust 9, 2021 at 8:31 pmkghaffari
Ansys EmployeeHi I would suggest evaluating the mesh size compared to your structure's smallest feature size, and also check if you can reduce the size of this 3D simulation. It is important that the minimum specified mesh size (set globally through the solver or locally through mesh constraint object) is smaller than the smallest features in your design (for example the space between two objects or thickness of a small layer).
Viewing 1 reply thread- The topic ‘Error code 9002 Lumerical CHARGE convergence error’ is closed to new replies.
4763
1565
1386
1242
