September 11, 2024 at 4:38 pm
victorafolabi21
SubscriberHello. I have tried to install Ansys Student 2024 R2 multiple times, and each time it always gives the same error. The installation gets stuck at 8% and doesn't progress for over 6 hours, then it suddenly speeds up to 100% with an error log. the installation error log can be found below
>>>--------------------------------------->Ansys installation: Wed Sep 11 20:51:41 2024Revision: 2024 R2###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fwgfx\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\common\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\commoninstall\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythext\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythcloudext\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlpviewer\HLPVIEWER.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\7zip\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-nvd3\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-context-menu\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-tree\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs-slider\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularui\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\bootstrap\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\d3\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ffmpeg\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\IntelCompiler\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\jquery\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ngInfiniteScroll\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\nvd3\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\qt\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\signalr\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\hdf5\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\zlib\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\mpi\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ansys\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addgeometry\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\ansys\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\solver\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error decompressing file:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error decompressing file:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\python_site_mapdl\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\mech\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_composites\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aas\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\stride\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\hoops\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geompara\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\designmodeler\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\artemis\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\lumerical\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\intelmkl2023.1.0\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\nexus\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\openjre\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\spaceclm\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfx\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfx\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\post\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfdpost\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\cpprestsdk\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\chemkin\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\chemkin\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fensap\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\post\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentu\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2d\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2ddp\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent3d\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\fluent\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight_components\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\polyflow\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\polyflow\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matpro\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\forte\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\forte\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\turbogrd\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\acad\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cat5\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\datakit\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\osm\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomproe\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\pe\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\ai\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomunig\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\nx\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\revit\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\se\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\sw\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speos\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\anscust\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speoslabs\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speosdata\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aqwa\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\aqwa\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\autodyn\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\autodyn\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\matcal\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matdes\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\acp\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\acp\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\shapeoptimization\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\additive_cl\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion_scdm_addin\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\student\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\license\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\config\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlplic\HLPLIC.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error decompressing file:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error decompressing file:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aview\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error extracting C:\Users\AFOLABI VICTOR\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\optislang\WINX64.7z:'C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\7zip\7z.exe' terminated after 1 attempts with the following error(s):Process failed to start: The system cannot find the file specified.Exit Code: 0ERROR: 7zip did not return any information to standard output. This usually indicates a problem.###### Error #######Error executing configuration script 'AnsConfigDiscoUnified.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1Registry key HKEY_CLASSES_ROOT\SpaceClaim.AnsysSCDM.242 or value creation error###### Error #######Error executing configuration script 'AnsConfigCommonDiscovery.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec {*}$execCommand"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigCommonDiscovery.tcl" line 30)###### Error #######Error executing configuration script 'AnsConfigADR.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigADR.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigCommon.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec {*}$execCommand"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigCommon.tcl" line 32)###### Error #######couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directory###### Error #######Error executing configuration script 'AnsConfigWB.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigWB.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigSpaceClaimUnified.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1Registry key HKEY_CLASSES_ROOT\SpaceClaim.AnsysSCDM.242 or value creation error###### Error #######Error executing configuration script 'AnsConfigCFX.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigCFX.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigCHEMKIN.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigCHEMKIN.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigEnSight.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigEnSight.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigFENSAP.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigFENSAP.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigCFDPost.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigCFDPost.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigFLUENT.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigFLUENT.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigPolyflow.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigPolyflow.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigFORTE.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigFORTE.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigRDWorkbench.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigRDWorkbench.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigTG.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigTG.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigSpeos.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec {*}$execCommand"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigSpeos.tcl" line 28)###### Error #######Error executing configuration script 'AnsConfigSpeosLabs.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigSpeosLabs.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigAQWA.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigAQWA.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigACP.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigACP.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigANSYS.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigANSYS.tcl" line 26)###### Error #######Error executing configuration script 'AnsConfigMotion.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigMotion.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigAVIEW.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigAVIEW.tcl" line 23)###### Error #######Error executing configuration script 'AnsConfigOptiSLang.tcl''C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 1couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directorywhile executing"exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"invoked from within"if { $config == 1 || $unconfig == 1 } {set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"set cmdPath ""if { ..."(file "C:\Users\AFOLAB~1\AppData\Local\Temp\ans_install_tmp11520\config\AnsConfigOptiSLang.tcl" line 23)>>>--------------------------------------->It seems the setup can't detect the 7z.exe and dll files. Here are things i tried: 1. I confirmed that the 7z.exe and dll files were in the "util " folder in the extracted folder.
2. I want to state that I extracted the folder from the downloaded zip file before running "setup.exe."
3. I have tried copying the 7z.exe file to my 'C:\Users\j\AppData\Local\Temp\ans_install_tmp2100\7zip' folder. It didn't solve it.
4. I have tried completely uninstalling previously installed Ansys software and deleting their folders before each new attempt, to no avail.
Please see other post:
https://innovationspace.ansys.com/forum/forums/topic/error-ampzexe-not-found-during-installation/
