April 17, 2024 at 10:58 ammohd hamzaSubscriber
This is Mohd Hamza Anwar from India, an undergraduate in electronics and communication engineering. I have a doubt related to Ansys simulation. I am simulating the wireless power coils for the pacemaker application for my dissertation in Ansys maxwell. For this I embedded the receiver coil inside the human body model which is available in Ansys. But it is giving me an error stating that coil terminals are not in the conducting path. I also added an insulating boundary to each coil but still facing the same issue. Please help me to know the solution for it.
Hope to get a positive response from your side at the earliest possible time as my deadline is approaching.
regards. -
April 19, 2024 at 3:08 amHDLIAnsys Employee
Hello Mohd,
Could you show your "Conductions path" in excitation? to check if the coil terminal is assigned correctly. Could you show both terminal and conductor?
HDLI
- The topic ‘error’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
1416
599
591
565
366
