April 24, 2024 at 10:48 pm
REBECA ROMERO
SubscriberMy partner and I have been failing to use SCADE Testing due to ERR - 1018, we have tried many times and most of them have been assisted by teachers and classmates, but nothing seems to work. The code generates succesfully from ANSYS SCADE but, when we try to connect Test with SUITE, the file cant be found or generated with SCADE Testing.
We also had troubles with ERR - 1012, which are now fixed.
Does anyone has any idea of what we could do, to fix it?
April 25, 2024 at 1:28 pm
Benjamin Descorps
Ansys EmployeeHello,
You should check that in the root operator is well specified in the used code generator configuration. If I refer to the CruiseControl example, the configuraiton "KCG_with_probes" is used to generate code.
In this configuraiton, it is mandatory to select the root operator of the application (in that case CruiseControl):
Hope this helps,
Benjamin Descorps
- The topic ‘ERR – 1018’ is closed to new replies.
5694
1891
1419
