May 2, 2019 at 8:47 pm
Zari
SubscriberHi,
I am Calculating a 2D fluid model (only Viscous model), and the residuals are as below, which it shows the epsilon is fluctuating.
Information of the model:Reynolds stress model, Quadric Pressure-strain, standard wall functions, default model constants
Solution methods: pressure-velocity: simple
Gradient: Green-Gauss node based
pressure: PRESTO!
momentum and viscosity and Re-stresses: second order Upwind
URFs:
Pressure: 0,3,
density: 0,5
Body forces: 1
Momentum: 0.6
Swirl velocity: 0.8
Turbulence kinetic energy, and, dissipation rate, and viscosity: 0.3
(I have reduced the turbulent residuals from 0.8 to 0.3 to see the effect on fluctuation of epsilon, which did not have an effect of fluctuation)
The mesh is a refined mesh, with an average element quality of 0.92 (stnd.dev: 0.24) and orthogonal quality 0.99 (stnd.dev: 0.05).
Do you have any suggestions for me to check the case and to improve the solution settings?
Zari
May 3, 2019 at 11:18 am
Forum ModeratorCreate a few monitor points and monitor (plot) velocity and k against iteration on these points. Also look at the results and try to understand what's going on: you may have picked up a transient in the flow field.Â
- The topic ‘Epsilon – the only fluctuating residual’ is closed to new replies.
6369
