April 13, 2026 at 2:25 pm
April 22, 2026 at 5:25 pm
Anilkumar
Ansys EmployeeHi User,
Thank you for reaching to Ansys Forum Support.
May I know what type of model is this and if you are using any Adaptive or dynamic meshing here? Does the geometry or mesh changing with time?
If that is the scanario then you might end up with the above error since the TempMean() calculator assumes a single, consistent connectivity so that each node/element can be followed in time; with AMR or topology changes, EnSight detects that connectivity is changing and issues the error instead of producing invalid temporal averages.
Best regards,
Anil
