April 12, 2023 at 1:37 pm
Wender Daniel
SubscriberHello, I want to simulate the divergence of the mode after exiting a optical fiber usign EME solver. How should I set the EME cells to get this mode expansion? -
April 12, 2023 at 8:05 pm
Guilin Sun
Ansys EmployeeIf I am correct, you want to simulate the divergence angle of a fiber mode in EME?
Ideally, you can either FDE or FDTD to get the farfield pattern. FDTD might be more intuitive. Once you get the farfield, you can refer to this exmaple to get the divergence angle: Creating line plots of far field projections
April 13, 2023 at 1:38 am
Wender Daniel
SubscriberHi Guilin Sun,
I am simulating an optical fiber edge coupled to an silicon inverse taper in EME. I want to get the increase in the coupling loss as a function of the distance of the fiber to the taper. I think that the mode divergence must be considered. How can I set the cell between the fiber and the taper to consider the increase in the mode size?
Thank you,
April 13, 2023 at 3:51 pm
Guilin Sun
Ansys EmployeeDo you mean you want to simulate the result with varying the distance between the input fiber and the edge coupler, where the gap is in air or other material without light confinement? In this case the gap part will need many modes to build up the fields accurately. you may also consider using import sourece for EME, with FDTD simulation of a fiber and air, and use farfieldexact to calculate the fields at any distance. The calcualted EH fields then can be imported into EME. Both methods work but need some time to experiment for a better results.
April 13, 2023 at 6:25 pm
Wender Daniel
SubscriberYes, that's exactly what I mean. How many modes in the EME cell are reasonable? I have tested up to 100 modes but didn't get the mode divergence.
April 14, 2023 at 4:08 pm
Guilin Sun
Ansys EmployeeSince the air gap does not support regular modes, you need to test the numbers as the fields are continuous there. When the gap is small, the beam may not change significantly. Such simulation to obtain the relationship between the coupling and gap distance is tedious and needs a lot of time to try.
April 16, 2023 at 9:42 pm
Wender Daniel
SubscriberHi Guilin,
I have another question.
I'm getting unphysical modes in the edge coupler cells. I wondering if these modes are leading me to incorrect results. Should I remove these modes from the simulation?
Thank you,
April 17, 2023 at 4:18 pm
Guilin Sun
Ansys EmployeeThe so-called unphysical modes are not propagating modes I guess. Instead they are radiation or leaky modes to help fulfilling field-continuity of the tangential components, which is the key principle of the EME method: the tangential fields are continuous.
April 19, 2023 at 2:52 am
April 19, 2023 at 4:32 pm
Guilin Sun
Ansys EmployeeUsually those modes are needed to have continuous tangential field. In some cases such modes contribute very little to the final results. You can play around to find the best condition for accurate result.
- The topic ‘EME Optical Fiber Mode Divergence’ is closed to new replies.
5824
