LS Dyna
LS Dyna
EM_CONTROL_MAGNET syntax issues
    • troy.baker
      I recently noticed something I didn't understand with the EM_CONTROL_MAGNET keyword. On page 385 of the keyword manual (https://lsdyna.ansys.com/wp-content/uploads/2025/04/LS-DYNA_Manual_Vol_III_R16.pdf) it mentions there are two inputs, both mcomp to turn on the keyword, and ncycm to set the number of cycles. So it would be written like this:
      *EM_CONTROL_MAGNET
      $# mcomp ncycm
      1 100
      However, when I use lsprepost to make a keyword file and include the EM_CONTROL_MAGNET keyword, there is no ncycm command, only the mcomp, and it is automatically written as:
      *EM_CONTROL_MAGNET
      $# mcomp
      1
      Moreover, with the syntax written by LSPP, the simulation will crash stating "forrtl: severe (164): Program Exception - integer divide by zero" after assembling Fem-Bem matricies, and building P mat, Q mat, and W mat through 100 percent.  This may be a problem with the syntax, or maybe the rebuilding of magnetic vector of a deforming magnet happens too often and there is a threshold somewhere between NCYCM being undefined and 100 that allows the simulation to complete.  If it helps, here is the EM chunk of my .k file
      *EM_PERMANENT_MAGNET
      $#      id       pid     mtype     north     south        hc
               1         1         1         2         1     21033
      *EM_CONTROL
      $#   emsol     numls         -   dimtype    nperio         -   ncylfem   ncylbem
               1       100                   0         0                   1         1
      *EM_CONTROL_MAGNET
      $#   mcomp
               1
      *EM_CONTROL_TIMESTEP
      $#  tstype    dtcons      lcid    factor     tsmin     tsmas     rlcsf    mecats
               3       0.0         0       1.0    1.0E-4      0.25        25         0
      *EM_CONTROL_COUPLING
      $#   thcpl     smcpl    thlcid    smlcid   thcplfl   smcplfl
               1         2         0         0         0         0
      *EM_SOLVER_FEMBEM_MONOLITHIC
      $#   mtype     stype    abstol    reltol     maxit
               0         1    1.0E-6    1.0E-4       100
      *EM_MAT_002
      $#     mid     mtype     sigma     eosid     murel     eosmu    deatht
               1         4       0.0         0       1.1         0    1.0E28
      *EM_EXTERNAL_FIELD
      $# fieldid     ftype      fdef     lcidx     lcidy     lcidz
               1         1         1         4         2         4
    • ErKo
      Hi
      Some keywords are not always fully implemented and done in LSPP so that could be the case.
      Please feel free to add the smallest of parts/meshes/ em example here and users/members can perhaps look at it (just say like a cube with max 20 elements or so).
      Also state version used NCPU…etc.
      All the best
      Erko
      • troy.baker
        Ciao,
        I did not realize that all keywords were not fully integrated with lspp, I thought that was only an issue with the workbench environment.
        My body is 0.06x0.01x0.005 with mesh a uniform cube sizing 0.001x0.001x0.001 (a mm scale body in SI units).  I am running Dyna 2025 R2 V4.13.2 with NCPI set to 1 and using SMP double-precision
        • ErKo
          If you add to LSDYNA Magnets snapping — Welcome to LS-DYNA Examples the below it works fine:
          see the help manual for ncycm (second variable below):
          *EM_CONTROL_MAGENT
          $#   mcomp
                   1         1
          Erko
        • troy.baker
          $# LS-DYNA Keyword file created by LS-PrePost(R) 2025 R2 (v4.13.2) - 10Jun2025
          $# Created on Apr-3-2026 (12:29:59)
          *KEYWORD
          *DEFINE_CURVE_TITLE
          Gravity
          $#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
                   1         0       1.0       1.0       0.0       0.0         0         0
          $#                a1                  o1
                           0.0                 0.0
                         0.003                 3.2
                         0.006                 6.5
                         0.009                 9.8
                           3.6                 9.8
          *DEFINE_CURVE_TITLE
          Field
                   2         0       1.0       1.0       0.0       0.0         0         0
          $#                a1                  o1
                           0.0                 0.0
                           0.1               -0.01
                           1.2               -0.03
                           1.7               -0.05
                           3.6               -0.05
          *DEFINE_CURVE_TITLE
          Zero's
                   4         0       1.0       1.0       0.0       0.0         0         0
          $#                a1                  o1
                           0.0                 0.0
                           3.6                 0.0
          *LOAD_BODY_Y
          $#    lcid        sf    lciddr        xc        yc        zc       cid
                   1       1.0         0       0.0       0.0       0.0         0
          *CONTROL_IMPLICIT_AUTO
          $#   iauto    iteopt    itewin     dtmin     dtmax     dtexp     kfail    kcycle
                   1        10         5    1.0E-8    1.0E-5       0.0         0         0
          *CONTROL_IMPLICIT_GENERAL
          $#  imflag       dt0    imform      nsbs       igs     cnstn      form    zero_v
                   1    1.0E-5         2         1         2         0         0         0
          *CONTROL_TERMINATION
          $#  endtim    endcyc     dtmin    endeng    endmas     nosol
                 3.5         0       0.0       0.0      20.0         0
          *MAT_ELASTIC
          $#     mid        ro         e        pr        da        db  not used  not used
                   1    1600.0   1318200      0.49       0.0       0.0         0         0
                   1         1         1         2         1     21033
          *EM_CONTROL
                   1       100                   0         0                   1         1
          $# This Part Here
          *EM_CONTROL_MAGNET
          $#   mcomp
                   1
          $#*EM_CONTROL_MAGNET
          $#   mcomp     ncycm
          $#         1       100
                   1         2         0         0         0         0
          *EM_MAT_002
          *EM_EXTERNAL_FIELD
                   1         1         1         4         2         4
          *EM_OUTPUT
          $     matS      matF      solS      solF      mesh
                   2         2         2         2         0
          *EM_DATABASE_PARTDATA
          $    outlv     dtout
                   1      1.16
          *NODE
          $#   nid               x               y               z      tc      rc
                 1             0.0             0.0             0.0       0       0
                 2           0.012             0.0             0.0       0       0
                 3           0.024             0.0             0.0       0       0
                 4           0.036             0.0             0.0       0       0
                 5           0.048             0.0             0.0       0       0
                 6            0.06             0.0             0.0       0       0
                 7             0.0          0.0025             0.0       0       0
                 8           0.012          0.0025             0.0       0       0
                 9           0.024          0.0025             0.0       0       0
                10           0.036          0.0025             0.0       0       0
                11           0.048          0.0025             0.0       0       0
                12            0.06          0.0025             0.0       0       0
                13             0.0           0.005             0.0       0       0
                14           0.012           0.005             0.0       0       0
                15           0.024           0.005             0.0       0       0
                16           0.036           0.005             0.0       0       0
                17           0.048           0.005             0.0       0       0
                18            0.06           0.005             0.0       0       0
                19             0.0             0.0           0.005       0       0
                20           0.012             0.0           0.005       0       0
                21           0.024             0.0           0.005       0       0
                22           0.036             0.0           0.005       0       0
                23           0.048             0.0           0.005       0       0
                24            0.06             0.0           0.005       0       0
                25             0.0          0.0025           0.005       0       0
                26           0.012          0.0025           0.005       0       0
                27           0.024          0.0025           0.005       0       0
                28           0.036          0.0025           0.005       0       0
                29           0.048          0.0025           0.005       0       0
                30            0.06          0.0025           0.005       0       0
                31             0.0           0.005           0.005       0       0
                32           0.012           0.005           0.005       0       0
                33           0.024           0.005           0.005       0       0
                34           0.036           0.005           0.005       0       0
                35           0.048           0.005           0.005       0       0
                36            0.06           0.005           0.005       0       0
                37             0.0             0.0            0.01       0       0
                38           0.012             0.0            0.01       0       0
                39           0.024             0.0            0.01       0       0
                40           0.036             0.0            0.01       0       0
                41           0.048             0.0            0.01       0       0
                42            0.06             0.0            0.01       0       0
                43             0.0          0.0025            0.01       0       0
                44           0.012          0.0025            0.01       0       0
                45           0.024          0.0025            0.01       0       0
                46           0.036          0.0025            0.01       0       0
                47           0.048          0.0025            0.01       0       0
                48            0.06          0.0025            0.01       0       0
                49             0.0           0.005            0.01       0       0
                50           0.012           0.005            0.01       0       0
                51           0.024           0.005            0.01       0       0
                52           0.036           0.005            0.01       0       0
                53           0.048           0.005            0.01       0       0
                54            0.06           0.005            0.01       0       0
          *PART
          $#        title
          beam
          $#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
                   1         1         1         0         0         0         0         0
          *SECTION_SOLID
          $#   secid    elform       aet         -         -         -    cohoff   gaskett
                   1         1         0                                     0.0       0.0
          *ELEMENT_SOLID
          $#   eid     pid      n1      n2      n3      n4      n5      n6      n7      n8
                 1       1       1       2       8       7      19      20      26      25
                 2       1       2       3       9       8      20      21      27      26
                 3       1       3       4      10       9      21      22      28      27
                 4       1       4       5      11      10      22      23      29      28
                 5       1       5       6      12      11      23      24      30      29
                 6       1       7       8      14      13      25      26      32      31
                 7       1       8       9      15      14      26      27      33      32
                 8       1       9      10      16      15      27      28      34      33
                 9       1      10      11      17      16      28      29      35      34
                10       1      11      12      18      17      29      30      36      35
                11       1      19      20      26      25      37      38      44      43
                12       1      20      21      27      26      38      39      45      44
                13       1      21      22      28      27      39      40      46      45
                14       1      22      23      29      28      40      41      47      46
                15       1      23      24      30      29      41      42      48      47
                16       1      25      26      32      31      43      44      50      49
                17       1      26      27      33      32      44      45      51      50
                18       1      27      28      34      33      45      46      52      51
                19       1      28      29      35      34      46      47      53      52
                20       1      29      30      36      35      47      48      54      53
          *SET_NODE_LIST_TITLE
          NODESET(SPC) 1
          $#     sid       da1       da2       da3       da4    solver       its         -
                   1       0.0       0.0       0.0       0.0                   1
          $#    nid1      nid2      nid3      nid4      nid5      nid6      nid7      nid8
                   1         7        13        19        25        31        37        43
                  49         0         0         0         0         0         0         0
          *SET_SEGMENT_TITLE
          South
                   1       0.0       0.0       0.0       0.0MECH               0
          $#      n1        n2        n3        n4        a1        a2        a3        a4
                   7         1        19        25       0.0       0.0       0.0       0.0
                  13         7        25        31       0.0       0.0       0.0       0.0
                  25        19        37        43       0.0       0.0       0.0       0.0
                  31        25        43        49       0.0       0.0       0.0       0.0
          *SET_SEGMENT_TITLE
          North
                   2       0.0       0.0       0.0       0.0MECH               0
                   6        12        30        24       0.0       0.0       0.0       0.0
                  12        18        36        30       0.0       0.0       0.0       0.0
                  24        30        48        42       0.0       0.0       0.0       0.0
                  30        36        54        48       0.0       0.0       0.0       0.0
          *BOUNDARY_SPC_SET
          $#    nsid       cid      dofx      dofy      dofz     dofrx     dofry     dofrz
                   1         0         1         1         1         1         1         1
          *END
        • ErKo
          The above example runs fine with:
          *EM_CONTROL_MAGENT
          $#   mcomp
                   1         1
          But this keyword is never used I saw so you do not need (magnetization or scalar potential follows the elements so does not need to really be recomputed even if part bends)
          Used official LS-Dyna rel 16.1.1-20 (you stated the LSPP rel. that is not important, it is the solver below that is):
               |  Version : mpp d R16                              |
               |  Revision: R16.1.1-20-g0c90cad538
          (I would not suggest using any other rel. for em analysis – only official rel R16 as the one stated above)
          All the best
          Erko
        • troy.baker
          My institution has licenses for Ansys 2025r2, and probably wont update that until 2026r2.  Currently only 2026r1 is released as far as I know.  Is there that much of a gap between the EM keywords between the release 16.1.1 and the release that would come installed with a full 2025 r2 license?
          Solver output files state:
               |  LS-DYNA, A Program for Nonlinear Dynamic         |
               |  Analysis of Structures in Three Dimensions       |
               |  Date    : 05/14/2025    Time: 11:18:04           |
               |  Version : smp d R14                              |
               |  Revision: R14.1.1-16-gfadfb49b17
          So i believe that is release 14.1, which would be the 2023 version.  I previously used the 2023 R2 license and updated it a few months ago, maybe it only updated files related to workbench and not Dyna.  Although the LSrun files are stored in Program Files/ANSYSInc/v252 where the rest of the Ansys 2025 version files should be kept instead of v232, where the 2023 version files should be.  Is there a specific way to run an update for LS dyna under the license key i have without having to uninstall, clear all files, and reinstall the rest of my Ansys programs?
          I ask becasue once using the two argument based EM_CONTROL_MAGNET keyword, I run into error with
          *EM_OUTPUT_FORCES
          $#    iout     outdt     lcoff        sf
                   1       0.0         0       1.0
          where it says the line relating to arguments is incorrect:
           *** Error 10246 (KEY+246)
               line contains improperly formatted data
                 reading *EM_OUTPUT
                    At line# 78 of file
           C:\Users\user\filepath\Testing.k
                    1       0.0         0       1.0
          It references EM_OUTPUT but then the commands under the line for EM_OUTPUT_FORCES, so maybe the older release doesn't recognize the output_forces keyword
    • ErKo
      Do not use WB LS-Dyna (not supported only resistive heat solver is) for this and do not use R14.
      For EM always use official LS-Dyna rel 16.1.1-20 (you stated the LSPP rel. that is not important, it is the solver below that is):
      You can talk to your Uni and they can download and install R16.
      LSDYNA Download / Install Overview
      See here for credentials
      LS-Dyna License Manger – Network License Registration
      All the best – that is it for me – happy easter
      and good luck
      Erko
