Element orientation in ansys apdl command
    • Mortaza
      Hello, I want to model an orthotropic composite cylindrical shell in the Ansys APDL command. How can I define the element coordinate system with orientation all over the shell, like rosette and orientation in ACP of ansys workbench?
    • ErKo
      Hi
      See the esys command in the help manual.
      Some post that might help also:
      /forum/forums/topic/rotating-esys-in-a-section-in-apdl-around-element-center-points/
      If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
      Hope that helps
      • Mortaza
        Yes, it worked. Initially, I established an appropriate local coordinate system using the “LOCAL” command. Subsequently, I assigned this system to the element’s coordinate system using the “ESYS” command.
        Thank you.
    • Govindan Nagappan
      Hi Mortaza,
      You can use sectype and secdata commands.
      Check command reference guide for more details:
      SECTYPE (ansys.com)
      SECDATA (ansys.com)
      Example:
      sectype,3,shell
      secdata,0.2,2,45                            ! thickness, material, theta
      secoff,top
      You can use emod to modify the esys
      emod,1,esys,13
      VM82 has layered elements, but this example there is no modification to ESYS - VM82 (ansys.com)
  • The topic ‘Element orientation in ansys apdl command’ is closed to new replies.
