November 15, 2020 at 8:10 am
andrein13
SubscriberThe primary winding of a transformer can be supplied with electrical voltage in the form of a pulse (for exemple rectangular signal similar to the PWM signal)?nThank you very much!n -
November 16, 2020 at 1:26 pm
Karthik Remella
AdministratorHello,nQuick clarification - which tool are you using?nThank you.nKarthikn -
November 16, 2020 at 1:34 pm
andrein13
SubscriberHello,nAnsoft Maxwell 14.0.n -
November 16, 2020 at 1:57 pm
Karthik Remella
AdministratorI moved this discussion to the 'Electronics' category for streamlining with our products. We should be responding to this very soon. nThank you.nKarthikn -
November 16, 2020 at 2:08 pm
icellb1
Ansys EmployeeHi, ,nYou can type in pwl(datasetname, time) or pwl_periodic(datasetname, time) function to create user specified dataset to define the waveform. Please see Maxwell online help: Maxwell Help > Working with Maxwell Projects and Designs > Working with Variables > Using Piecewise Linear Functions in Expressionsn -
November 30, 2020 at 3:02 pm
singhvipin4291
SubscriberHloo Sir ,nPlease help me to make a simplore circuit which is basically pwm generation based on rotor position.nI don't have any idea in simplorer. I have maxwell 2D model and i want to run this using rotor position. this is switched reluctance motor control.n
Viewing 5 reply threads
- The topic ‘Electrical Transformer- PWM in primary winding’ is closed to new replies.
1306
