July 2, 2024 at 12:50 pm
Pankaj Rajput
AdministratorOn 2024-07-09, Ansys will change the destination IP address of all application/client communication with Elastic Licensing. For most users, this change will be transparent: no configuration changes are needed, and Elastic Licensing will continue to work without issue. Â Â
If you have defined a firewall or proxy rule that directly references the IP address of the Elastic Licensing gateway as opposed to the DNS entry, you will need to add the following addresses to those rules: 52.170.31.177 and 20.16.190.221. Â Â
If you are using Dynamic DNS-based firewall or proxy rules, or indeed no firewall or proxy rules, no change is necessary as the existing laas.fnocc.com rule will redirect to the appropriate location.
July 9, 2024 at 10:28 am
Ashutosh Kumar
Ansys EmployeeUpdate: This activity has been completed successfully.Â
- The topic ‘Elastic Licensing DNS gateway changes’ is closed to new replies.
