March 5, 2024 at 6:36 am
coleen.dizon
SubscriberI am trying to export the E-field quantity of a simulation by writing it to a .reg file. However, after checking the file, it shows that the elements are empty. Why does this happen and how can I make it not empty?
March 6, 2024 at 3:45 pm
Reshmi Raghavan
Ansys EmployeeHello Coleen,
You can export out the E field values from Maxwell in the form of a .fld file. You can make use of the field calculator for the same. Please follow the below steps to extract the same.
Open field calcualtorÂ
Input> Quantity >E
Input>Geometry>Select the goemetry where the field has to be exported
Output>Value
Output >Write >Sale the .fld file
The saved fld file can be imported into an excel for further postprocessing.
March 21, 2024 at 3:49 am
coleen.dizon
SubscriberHi Reshmi,
I tried writing the fields quantity to a .fld file. When I imported it in excel, it also showed empty elements. Though when I also put the geometry before saving to a file, it gives me a value.
- The topic ‘E field written to a register file is empty’ is closed to new replies.
5799
