February 23, 2022 at 12:31 am
franck.joel33
SubscriberHello everyone,
In Ansys, how do you simulate an overhead conductor exposed to a sinusoidal load? How will the tension force of the cable be considered if all displacement and rotation at the two ends of the line are blocked, as described in the reference attached? In the reference, the software Code Aster is used, and I want to the same simulation using ansys.
thank you
February 23, 2022 at 2:03 ampeteroznewman
SubscriberHere is a relevant discussion: /forum/discussion/36105/power-line-cable-behavior-simulation/p1
February 23, 2022 at 2:24 pmfranck.joel33
SubscriberThank you, @peteroznewman. In the second and their paragraphs of the methodology section, I don't know how I can incorporate the time integration schemein ANSYS and the amplitude of the force. I'd love it if you could explain in detail how to handle it in ANSYS.
February 23, 2022 at 4:19 pmfranck.joel33
SubscriberWhich analysis system should i use in this case? ls dynamic or transient system
thank you
February 24, 2022 at 1:08 pmpeteroznewman
SubscriberYou would use Transient Structural to perform nonlinear transient dynamics simulations. This uses a time integration scheme to integrate the equations of motion of the system.
Take some of the free courses available to get an introduction to dynamics in ANSYS. You should do a linear Modal analysis first to check if it is vibrating as you expected.
/courses/index.php/courses/modal-analysis/
/courses/index.php/courses/topics-in-modal-analysis-using-ansys-mechanical/
You should do a linear Harmonic Response to see the effect of the sinusoidal force.
/courses/index.php/courses/topics-in-harmonic-response-analysis/
Then you can get into Transient Structural analysis where nonlinear effects can be incorporated.
/courses/index.php/courses/time_integration/
/courses/index.php/courses/time-domain-dynamic-problems/
/courses/index.php/courses/structural-dynamics/
Viewing 4 reply threads- The topic ‘dynamic of overhead conductor’ is closed to new replies.
5209
1859
1387
1255
